routing policy ip reachability
sgtbilko711
I am looking to set up a ip reachability policy. I have never dont it before and am looking information on it either by you telling me or someone showing me were good documintation is on this.
Chris
Jon
Ok it looks right but let me run this by you.
If i have traffic going out one ip interface on a router and i have the 6500 check to see if it is up. whn it goes down i want to send it to a new ip interface.
looking over the doc. it looks like it but i am not sure.
Here is a test config that I had setup to check the same stuff. The toplogy that I used was like R1 --> R2 and R3 and both R2 and R3 inturns connect back to R4.
R2-----
R1--- R4
R3-----
The test was to use IPSLA and object tracking to fail-over the traffic from R1 to either of the connection in case of an indirect failure in the connectivity. I was pinging the R4 loopback addresses from R1 and tried shutting down the R2 and R3 link to R4.
HTH, Please rate if it does.
-amit singh
