Best practice lan configuration
I have 4 Cisco 2960 switches and 3 unmanaged switches. All are connected via fiber cable to a core switch 4503-3 and it is connected to a VPN router and internet router. (still don't have access to the routers yet)
I know I have to replace the unmanaged switches but it will be soon. Meanwhile, I have done the following in the managed switches:
In each switch and its ports:
udld enable
udld aggressive
ip subnet-zero
no ip source-route
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
spanning-tree loopguard default
spanning-tree uplinkfast
vlan internal allocation policy ascending
and in each access port:
switchport access vlan 8
switchport mode access
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
spanning-tree guard root
The ports that are connected to the core switch configuration are switch port trunk only.
The core sw configurations are:
power redundancy-mode redundant
no file verify auto
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1-250 priority 8192
ports between managed switches:
switchport mode trunk
spanning-tree guard loop
ports between unmanaged switches:.
switchport access vlan 139
ports between servers:
switchport access vlan 100
port to the routers
no switchport
ip address **
router rip
version 2
network ***
no auto-summary
ip route 0.0.0.0 0.0.0.0 ***
ip route *** *** ***
ip http serve
I want the best practice network and I am trying to see why internet is slow
Many thanks
balaji.bandi
i would suggest always control allowing vlan required trunk port connected to switch
switchport trunk allowed vlan  x,y,z
avoid RIP and use any other IGP like OSPF and if cisco EIGRP
if you using IGP avoid static routes.
this is different issue, many possibilities here - port negotiation end to end, any packet drops on the interface ?
Routing loops, Layer  looops ? like list goes on.
you need to check below :
1. directly connecting to ISP router is the internet works ?
2. how about connecting to Core internet works ?
3. Access switch internet works ?
4. i would not expect great test on hub/ un managed switch expected greater results. ? but testing good ?
BB
balaji.bandi
BB
Dear Mr Balahi
Thank you very much for the support. I have done the setting you recommanded.
I am not able to access the router yet. but the core switch 4503E is connected to two routers ( vpn&internet) vpn connection is fast but the internet is not. vpn setting is rip while the internet is static.
I connected my laptop to the router and the speed was 10mb which is what is the subscription but when I connected to the core switch, the speed was 100kb. I disabled all other ports too but still the same speed.
post again the configuraiton of the switch port connected.
check the port have any errors, speed negotiation ? any MTU issue on the ports ?
BB
Dear Balaji, thank you. here is the configuration and outpot of the interface connected to the router
interface GigabitEthernet3/10
description LINK TO INTERNET ROUTER
no switchport
ip address 10.x.x.x
GigabitEthernet3/10 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is xxx.xxxx(bia xx.xxx)
Description: LINK TO INTERNET ROUTER
Internet address is 10.x.x.x/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is on, output flow-control is on
Last input 00:00:02, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 6451000 bits/sec, 587 packets/sec
5 minute output rate 602000 bits/sec, 468 packets/sec
L3 in Switched: ucast: 160638916 pkt, 217254623710 bytes - mcast: 0 pkt, 0 byt es
L3 out Switched: ucast: 144936451 pkt, 18444109246 bytes - mcast: 0 pkt, 0 byt es
161236946 packets input, 220210434866 bytes, 0 no buffer
Received 539695 broadcasts (0 IP multicasts)
145030831 packets output, 21296450280 bytes, 0 underruns
0 lost carrier, 0 no carrier
sh int g 3/10 status
Port Name Status Vlan Duplex Speed Type
Gi3/10 LINK TO INTERNET R connected routed a-full a-1000 10/100/1000-TX
sh int g 3/10 mtu
Port Name MTU
Gi3/10 LINK TO INTERNET R 1500
#sh int g 3/10 stats
GigabitEthernet3/10
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 0 0 0 0
Route cache 0 0 0 0
Hardware 161402067 220441944095 145165937 21313112630
Total 161402067 220441944095 145165937 21313112630
