Best way to test QoS scenarios in a lab environment
shikamarunara
Level 4
Level 4
I have a frame relay/PSTN/telephony network configured in a lab and I would like to test out QoS syntax in different congested-link situations.  Can anyone recommend a method or device that will generate traffic, enough traffic to saturate a frame or ethernet link?
Joseph W. Doherty
Disclaimer
The Author of this posting  offers the information contained within this posting without   consideration and with the reader's understanding that there's no      implied or expressed suitability or fitness for any purpose.    Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind.  Usage of   this posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
I've used the freebie PCATTCP.  It can optionally generate UDP traffic at rate you specify.  I've used it to easily saturate a DS3.
andrew.prince
Level 10
Level 10
ping
Joseph W. Doherty
Disclaimer
Posting
