BGP and Static Routing Precedence
dclarolh1
I have two default routes. One defined staticly and one defined via BGP. How do I give the static route precedence?
John Blakley
If they're the same route to different destinations, the static route will win due to lower AD. Just install the router without a higher AD than 20 or 200 (depending on the route type). I hope I understand your question
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
HTH,
John
dclarolh1
Haha, I just figured this out after writing that. I mistyped the subnet as 255.255.255.0 on the default route instead of 0.0.0.0. Fixed the problem.
