11-21-2013 10:30 AM - edited 03-07-2019 04:43 PM
Hi all,
My topology is very simple
R1 ------------------------- R2 ------------------------R3 -------------------------- R4
R1 is advertising 3 subnets. 192.168.1.0/24, 192.168.2.0/24, 192.168.3.0/24. All routers are in separate AS (1,2,3,4 respectively). Performing aggregation on R3
R3
router bgp 3
aggregate-address 192.168.0.0 255.255.0.0 summary-only
on R4
R4#show ip bgp 192.168.0.0 255.255.0.0
BGP routing table entry for 192.168.0.0/16, version 39
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Flag: 0x820
Not advertised to any peer
3, (aggregated by 3 3.3.3.3)
10.1.34.3 from 10.1.34.3 (3.3.3.3)
Origin IGP, metric 0, localpref 100, valid, external, atomic-aggregate, best
Now on R3 if i use the keyword as-set, it removes the bolded atomic-aggregate, like below
R3
aggregate-address 192.168.0.0 255.255.0.0 as-set summary-only
on R4
BGP routing table entry for 192.168.0.0/16, version 40
Flag: 0x820
3 2 1, (aggregated by 3 3.3.3.3)
Origin IGP, metric 0, localpref 100, valid, external, best (its gone)
R4#
Is this normal behavior ?
Solved! Go to Solution.
11-21-2013 10:46 AM
Yes it is. Seeing the atomic-aggregate indicates to the receiving router that there are more AS's behind the one that's advertised it. If you'll notice that R3 has set itself as the only AS in the path and advertised that to R4. R4 sees it, but it only knows about R3. When you set as-set on the summary, it tells R3 to not aggregate all AS'es behind it, but instead pass the complete as-path to the upstream neighbor.
Flag: 0x820
R3
on R4
Flag: 0x820
R4#
HTH,
John
*** Please rate all useful posts ***
11-21-2013 10:46 AM
Flag: 0x820
R3
on R4
Flag: 0x820
R4#
HTH,
John
