bgp conditional peering
illusion_rox
Level 7
Level 7
hi everyone, i had a question regarding bgp.
Suppose i have 2 routers peering with an ISP ( whether same ISP or 2 different ISP ) lets name these routers RA and RB. i want RB to make a peering session with its ISP if and only if RA fails its bgp session, now u can also assume that RA fails completely or just loses its bgp connection, in either case i want RB to start its own bgp session, so i want to make RB backup of RA in terms of BGP.
how can it be possible
6 Replies 6
criss_noh
yes. that is commonly used. you can have backup line via BGP or have 2 paths likely loadbalancing.
can u kindly tell me that how its possible ? what configuration i have to do ???
The only way i could think of achieving this is by configuring BGP over loopbacks and making sure that it is reachable only when your primary links come up.
Narayan
that is very simple. you just command maximum-path 2. but please make sure all of BGP best path selection procedure.
router bgp 10
neighbor x.x.x.x remote-as xxxx
maximum-paths 2
end
etienne.basset
Level 4
Level 4
hello
i don't know exactly why you want to to this but you should do like this :
RA <=EBGP=> ISP
RB <=EBGP=> ISP
AND
RA <=IBGP=> RB
then RA set localpref150 on incoming routes,
RB do as path prepend on outgoing routes...
it's more clean than 'conditionnal peering'
Etienne
Dear etienne,
I guess that he wants to have 2 paths on the same router. this means link redundency vis bgp not router redundency.
