bgp default route using "aggregate-address"
Kashish_Patel
Level 2
Level 2
I read/heard somewhere that we can generate default route in BGP using "aggregate-address" command... I did not understand this. Could any expert explain this to me how default route is generated?
Thanks.
2 Accepted Solutions
Harold Ritter
Hi Kashish,
In principle you could use the aggregate-address command to generate a default route but in practice IOS does not allow you to do that and returns the following error message:
r1(config-router)#aggregate-address 0.0.0.0 0.0.0.0 summary-only
% Aggregating to create default makes no sense,
use a network statement instead.
r1(config-router)#
Hi Kashish,
This has been the behavior for as long as I can remember.
Harold Ritter
Hi Kashish,
r1(config-router)#
Thanks Harold.
Did this command use to work on old IOS versions and getting deprecated in favor of network command for newer ones? Just curious.
Hi Kashish,
Thanks, This helps!
