BGP - Load Balance or Load Sharing
Claudio A.
Hi All,
I need a help to define the best way to configure one new router in our customer.
The scenario is: provide a ISR4331 with IOS SL-4330-IPB-K9 to connect at two ISP (different companies) with BGP protocol. My question is: Can we configure a load balance feature with two different ISPs and different AS prefixes? or Load Sharing?
Claudio Arriagada
2 Accepted Solutions
Reza Sharifi
You can load share between the 2 ISPs.
Have a look at this document for drwaing and config examples:
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html#anc22
Joseph W. Doherty
Yes, but to do so with different ASs you need to use a secret/hidden command, bgp bestpath as-path multipath-relax.
Reza Sharifi
Joseph W. Doherty
