BGP neighbours with loopback interface.
Harmeet Singh
I configured BGP in 2 different ASN. All route did not exchange properly. I am Attaching the topology and configuration of all routers. Plz find the mistake and help me to correct it.
Router 1
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface Loopback5
ip address 5.5.5.5 255.255.255.255
interface Serial0/0
ip address 10.0.0.1 255.0.0.0
serial restart-delay 0
no dce-terminal-timing-enable
interface Serial0/1
ip address 30.0.0.1 255.0.0.0
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
router bgp 10
no synchronization
bgp log-neighbor-changes
network 1.1.1.1
network 5.5.5.5
network 10.0.0.0
network 30.0.0.0
neighbor 2.2.2.2 remote-as 10
neighbor 2.2.2.2 update-source Loopback1
neighbor 3.3.3.3 remote-as 20
neighbor 3.3.3.3 ebgp-multihop 2
neighbor 3.3.3.3 update-source Loopback1
no auto-summary
no ip http server
no ip http secure-server
ip route 2.2.2.2 255.255.255.255 30.0.0.2
ip route 3.3.3.3 255.255.255.255 10.0.0.2
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
Router 2
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback1
ip address 2.2.2.2 255.255.255.255
interface Loopback10
ip address 11.11.11.11 255.255.255.255
interface Serial0/0
ip address 20.0.0.1 255.0.0.0
interface Serial0/1
ip address 30.0.0.2 255.0.0.0
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
router bgp 10
no synchronization
network 2.2.2.2
network 11.11.11.11
network 20.0.0.0
network 30.0.0.0
neighbor 1.1.1.1 remote-as 10
neighbor 1.1.1.1 update-source Loopback1
no auto-summary
no ip http server
ip route 1.1.1.1 255.255.255.255 30.0.0.1
ip route 3.3.3.3 255.255.255.255 20.0.0.2
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
Router 3
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback1
ip address 3.3.3.3 255.255.255.255
interface Loopback15
ip address 15.15.15.15 255.255.255.255
interface Serial0/0
ip address 10.0.0.2 255.0.0.0
interface Serial0/1
ip address 20.0.0.2 255.0.0.0
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
router bgp 20
no synchronization
network 3.3.3.3
network 10.0.0.0
network 15.15.15.15
network 20.0.0.0
neighbor 1.1.1.1 ebgp-multihop 2
neighbor 2.2.2.2 ebgp-multihop 2
no auto-summary
no ip http server
ip route 1.1.1.1 255.255.255.255 10.0.0.1
ip route 2.2.2.2 255.255.255.255 20.0.0.1
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
cadet alain
when no auto-summary is enabled you must specify an exact match for the prefixes you want to advertise with the network command by using the mask keyword and specifying the mask of the prefix as it is in the routing table.
eg :
router bgp 20
network 3.3.3.3 mask 255.255.255.255
Regards.
Alain
