BGP-no synchronization
Anukalp S
Level 7
Level 7
I could not see "no synronization" and "no auto-summary" command under BGP config after configuring both. I have cisco 1900 router running cisco IOS 15.1(4)M4.Can any one pls suggest.
7 Replies 7
Steven Clinton
Level 3
Level 3
Those are cisco's default commands, default commands will not show up. If you change it to auto summary and do a show run it will show up, but then change it back to no auto summary it will disappear
InayathUlla Sharieff
Hi Anu,
Do you mean this:
R1(config-if)#router eigrp 10
R1(config-router)#network 192.168.0.1
R1(config-router)#no auto-summary
R1(config-router)#end
R1#sh run | in auto-summary
no auto-summary>>>>>>>>> This you are not seeing?
2)
R1(config)#router bgp 1
R1(config-router)#no sy
R1(config-router)#no synchronization
R1#sh run  | in synchronization
no synchronization  >>>>>>>>> This you are not seeing?
My ios:
R1#sh ver
Cisco IOS Software, 3600 Software (C3640-JK9O3S-M), Version 12.3(14)T7, RELEASE SOFTWARE (fc2)
If yes then i could look for bug.
REgards
Inayath
Yes Inayat.. i am not seeing "no synshronization" & "no auto-summary" under BGP aven after configuring it.Below are logs.
RTR#sh run | i synchronization
RTR#
RTR#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
You can check with #show ip protocol if you have sync & auto-summary enabled.
Can you please provide output of:
#sh run | s router bgp
#sh ip protocol
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Hi blau,
Here is output.
RTR#sh ip protocols
*** IP Routing is NSF aware ***
Routing Protocol is "ospf 1"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Router ID a.b.c.d
  It is an autonomous system boundary router
Redistributing External Routes from,
    bgp 65255, includes subnets in redistribution
  Number of areas in this router is 1. 1 normal 0 stub 0 nssa
  Maximum path: 4
  Routing for Networks:
    x.x.x.x x.x.x.x area 0
  Routing Information Sources:
    Gateway         Distance      Last Update
    x.x.x.x       110      1d01h
  Distance: (default is 110)
Routing Protocol is "bgp 65255"
  IGP synchronization is disabled
  Automatic route summarization is disabled
  Redistributing: ospf 1
  Neighbor(s):
    Address          FiltIn FiltOut DistIn DistOut Weight RouteMap
    x.x.x.x
  Maximum path: 1
    x.x.x.x          20          00:01:44
  Distance: external 20 internal 200 local 200
RTR#sh run | s router bgp
router bgp 65354
bgp log-neighbor-changes
network x.x.x.x mask x.x.x.x
neighbor x.x.x.x remote-as 9321
neighbor x.x.x.x soft-reconfiguration inbound
As you can see sync and summarization is disabled which is default state so you will not see these command on configuration.
When you configure:
  auto-summary
  synchronization
under BGP, you will see them in configuration and also in sh ip protocol output as enabled.
Best Regards
Steven Clinton
Level 3
Level 3
Do a 'show run all' , this will include the default configs. Or to see specifically what you are try to see with.BGP:
sh run all | sec router bgp
