BGP Question
lamav
Level 8
Level 8
router BGP 65000
network 1.1.1.0 mask 255.255.255.0
ip route 1.1.1.0 255.255.255.0 null0 254
I need the static route and it has to be an exact match because the network command is utilizing the 'mask' keyword. Thats not my question.
What if I wanted to advertise an aggregate address, do I still need the static route?
router BGP 65000
aggregate-address 1.1.1.0 255.255.255.0 as-set summary-only
Edison Ortiz
Yes, you still need the static route because the route needs to be brought into BGP so it can be aggregated and in order to bring the route into BGP, it must exist in the RIB.
__
Edison.
Edison Ortiz
__
Edison.
Thanks, Edison...Thats what I figured, just wanted to make sure.
Hope all is well with you...
Victor
Hope all is well with you and thanks for the rating.
