BGP rib-failure
rahul.bambhnia
as i have three router and configure basic bgp but suddenly i got rib-failure in sh ip bgp. below is sh run configuration please help me resolved this.
R1#
interface Loopback0
ip address 151.1.1.1 255.255.255.0
interface Loopback1
ip address 151.2.1.1 255.255.255.0
interface Loopback2
ip address 151.3.1.1 255.255.255.0
interface Loopback3
ip address 151.4.1.1 255.255.255.0
interface Loopback4
ip address 153.1.1.1 255.255.255.0
interface Loopback5
ip address 153.2.1.1 255.255.255.0
interface Serial2/0
ip address 150.1.1.1 255.255.255.252
serial restart-delay 0
interface Serial2/3
ip address 192.168.1.1 255.255.255.252
ip policy route-map rahul
shutdown
router bgp 111
no synchronization
bgp log-neighbor-changes
redistribute connected
neighbor 150.1.1.2 remote-as 500
no auto-summary
R3#
interface Ethernet1/0
ip address 200.1.1.1 255.255.255.0
duplex half
interface Serial2/0
ip address 150.1.1.2 255.255.255.252
interface Serial2/1
ip address 150.1.1.6 255.255.255.252
router bgp 500
no synchronization
network 200.1.1.1
neighbor 150.1.1.1 remote-as 111
neighbor 150.1.1.5 remote-as 222
no auto-summary
R2#
interface Loopback0
ip address 152.1.1.1 255.255.255.0
interface Loopback1
ip address 152.2.1.1 255.255.255.0
interface Loopback2
ip address 152.3.1.1 255.255.255.0
interface Loopback3
ip address 152.4.1.1 255.255.255.0
interface Loopback4
interface Loopback5
interface Serial2/1
ip address 150.1.1.5 255.255.255.252
router bgp 222
no synchronization
neighbor 150.1.1.6 remote-as 500
no auto-summary
R3 #sh ip bgp
BGP table version is 27, local router ID is 200.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, x best-external
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
r> 150.1.1.0/30 150.1.1.1 0 0 111 ?
r> 150.1.1.4/30 150.1.1.5 0 0 222 ?
*> 151.1.1.0/24 150.1.1.1 0 0 111 ?
*> 151.2.1.0/24 150.1.1.1 0 0 111 ?
*> 151.3.1.0/24 150.1.1.1 0 0 111 ?
*> 151.4.1.0/24 150.1.1.1 0 0 111 ?
*> 152.1.1.0/24 150.1.1.5 0 0 222 ?
*> 152.2.1.0/24 150.1.1.5 0 0 222 ?
*> 152.3.1.0/24 150.1.1.5 0 0 222 ?
*> 152.4.1.0/24 150.1.1.5 0 0 222 ?
*> 153.1.1.0/24 150.1.1.1 0 0 111 ?
* 150.1.1.5 0 0 222 ?
*> 153.2.1.0/24 150.1.1.1 0 0 111 ?
R3#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP
+ - replicated route, % - next hop override
Gateway of last resort is not set
150.1.0.0/16 is variably subnetted, 4 subnets, 2 masks
C 150.1.1.0/30 is directly connected, Serial2/0
L 150.1.1.2/32 is directly connected, Serial2/0
C 150.1.1.4/30 is directly connected, Serial2/1
L 150.1.1.6/32 is directly connected, Serial2/1
151.1.0.0/24 is subnetted, 1 subnets
B 151.1.1.0 [20/0] via 150.1.1.1, 00:30:23
151.2.0.0/24 is subnetted, 1 subnets
B 151.2.1.0 [20/0] via 150.1.1.1, 00:30:23
151.3.0.0/24 is subnetted, 1 subnets
B 151.3.1.0 [20/0] via 150.1.1.1, 00:30:23
151.4.0.0/24 is subnetted, 1 subnets
B 151.4.1.0 [20/0] via 150.1.1.1, 00:30:23
152.1.0.0/24 is subnetted, 1 subnets
B 152.1.1.0 [20/0] via 150.1.1.5, 00:40:46
152.2.0.0/24 is subnetted, 1 subnets
B 152.2.1.0 [20/0] via 150.1.1.5, 00:40:46
152.3.0.0/24 is subnetted, 1 subnets
B 152.3.1.0 [20/0] via 150.1.1.5, 00:40:46
152.4.0.0/24 is subnetted, 1 subnets
B 152.4.1.0 [20/0] via 150.1.1.5, 00:40:46
153.1.0.0/24 is subnetted, 1 subnets
B 153.1.1.0 [20/0] via 150.1.1.1, 00:30:23
153.2.0.0/24 is subnetted, 1 subnets
B 153.2.1.0 [20/0] via 150.1.1.1, 00:30:23
200.1.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 200.1.1.0/24 is directly connected, Ethernet1/0
L 200.1.1.1/32 is directly connected, Ethernet1/0
R3#sh ip bgp rib-failure
Network Next Hop RIB-failure RIB-NH Matches
150.1.1.0/30 150.1.1.1 Higher admin distance n/a
150.1.1.4/30 150.1.1.5 Higher admin distance n/a
even i did not used and any IGP .
Francesco Molino
as per your output, BGP is saying on R3 a rib-failure for 2 networks because there are directly connected and the AD of a connected is better than AD from BGP routes.
This is a normal behaviour and I don't see any special issues on that output.
You are getting that output because on R1 and R2, you redistribute connected without filtering. When these 2 subnets arrives in R3 and it see that he have a better path then it will flag those 2 subnets as rib-failure.
There is a good document explain that very simply, that has been mentionned on this forum:
http://blog.ipspace.net/2007/12/what-is-bgp-rib-failure.html
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
rahul.bambhnia
thanks you so much for very quick reply
so could please tell me which cmd i have to hit on router so that i can resolve this issues
thanks a lot in advance
I will not advertise these connected networks between routers.
I will do On R1 (same should apply to R2 but networks will be changed):
ip prefix-list LOCAL seq 5 permit 150.1.1.0/30
Route-map LOCAL deny 10
 match ip address prefix-list LOCAL
route-map LOCAL permit 20
router bgp 111
 redistribute connected route-map LOCAL
OR Another way to do this, is :
ip prefix-list LOCAL seq 5 deny 150.1.1.0/30
ip prefix-list LOCAL seq 10 permit 0.0.0.0/0 le 32
route-map LOCAL permit 10
router bgp 111
Francesco
thanks  a lot .
its works..
