BGP Routes specific to neighbor?
dclarolh1
I would only like to advertise certain BGP networks to specific neighbors. How can this be achieved?
Any help is appreciated.
18 Replies 18
that's nx-os nexus,  I have been giving you commands for IOS for bgp
this is how you do it in nexus under address family
switch# configure terminal
switch(config)# ip prefix-list allowprefix 10 permit 192.0.2.0 eq 24
switch(config)# ip prefix-list allowprefix 20 permit 209.165.201.0 eq 27
switch(config) router bgp 65536:20
switch(config-router)# neighbor 192.0.2.1/16 remote-as 65536:20
switch(config-router-neighbor)# address-family ipv4 unicast
switch(config-router-neighbor-af)# prefix-list allowprefix in
Thank you.
Not sure what the :20 is in the AS number?
So my config would look more like this:
ip prefix-list xx-mpls-filter 10 permit 172.22.16.204 eq 32
ip prefix-list xx-mpls-filter 5 deny 0.0.0.0 eq 0
router bgp xxxx
neighbor x.x.x.x remote-as xxxx
prefix-list xx-mpls-filter in
Yes don't worry about the :20 not required your setup , and yes follow that method should work for you just change that last prefix list to le 32 so it blocks everything else 0.0.0.0/0 le 32
that output is usually in nexus to say your trying to configure something in wrong section , can you paste exactly what your doing so can see why its blocking it
