BGP to OSPF
baxta2712
Could anyone help me?
My simplified scenario is:
I have two iBGP neighbor
neighbor X.X.X.X
and
neighbor Y.Y.Y.Y
I am redistributing BGP into OSPF
and I need neighbor X.X.X.X to have lower metric than Y.Y.Y.Y in OSPF domain
how can I solve this?
thank you in advance
Hello Giorgi,
you can use an ACL to define BGP next-hop(s) to be matched
access-list 11 permit host A.B.C:D
route-map BGP-to-OSPF permit 10
match ip next-hop 11
set metric-type type-1
set metric 10
see match ip next-hop in command reference
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_pi/command/iri-cr-a1.html#GUID-8E887F08-155C-4D90-876D-F3F591BBDC6A
I have used this successfully in the past
Hope to help
Giuseppe
Giuseppe Larosa
Hello Giorgi,
you can use a route-map where you will set the seed metric
! match conditions here as needed
set metric 10
on second router you set an higher seed metric like 100, with two ASBR nodes the use of O E1 metric-type type-1 is recommended
router ospf 10
redistribute bgp route-map BGP-to-OSPF subnets
The subnets keyword is also important to avoid automatic summarization during redistribution
You may need a specifc command under router bgp to allow redistribution of iBGP into OSPF
router bgp
bgp redistribute-internal
see
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/command/bgp-a1.html#GUID-840E8371-2A6D-4B23-ADEA-4CAB4634C07E
Hope to help
Giuseppe
     I want to match only routes from certain neighbors, this routes may change and because of this I can not define routes in access-list.
Hello Giorgi,
set metric 10
Hope to help
Giuseppe
thank you
