BGP traffic priority
mediaworksnz
Level 2
Level 2
Hello, I had a case whereby user traffic passing through my router saturated the link and caused the BGP peering to drop.
What mechanism does a Cisco 1921 router to prioritise it's BGP keepalive traffic etc over normal user traffic.
You don't need to match tcp-179 as it should already be tagged. You can do a quick tcpdump to validate it.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
11 Replies 11
Francesco Molino
You can use QoS to do that.
By default, all routing protocol is tagged with DSCP CS6. On several platforms, there's a hidden system queue for routing protocol to take care of this issue (not flapping when large amount of traffic goes over interfaces). I don't recall if this is the case on 1921.
However, you can create a qos policy to make sure this traffic (CS6) has a reserved bandwidth for example, to make sure it won't flap next time.
Francesco
Fransesco is completely correct, the hidden queue he is mentioned is called "pak priority". Unfortunately bgp is not using this feature as other routing protocol is. So a qos policy needs to be configured to handle the bgp traffic.
/Mikael
Thank you So how would you recommend I adjust my QoS policy-maps.
i.e. should I simply add CS6 to my 'Multi-Media' class map ?
Thank you kindly for any advice.
Currently I have the following:
class-map match-any IA-High
match ip dscp cs3
match ip dscp af31
match ip dscp af32
match ip dscp af33
class-map match-any Multi-Media
match ip dscp ef
match ip dscp cs4
match ip dscp af41
match ip dscp af42
match ip dscp af43
class-map match-any DataTrans
match ip dscp af11
match ip dscp af12
match ip dscp af13
class-map match-any IA-Low
match ip dscp cs2
match ip dscp af21
match ip dscp af22
policy-map QUEUES
class Multi-Media
priority level 1
class IA-Low
bandwidth remaining percent 10
class DataTrans
bandwidth remaining percent 60
class IA-High
bandwidth remaining percent 15
class class-default
policy-map WAN
class class-default
shape peak 30000000
service-policy QUEUES
You can add it wherever you want.
Usually i prefer creating a distinct class to reserve a small amount of bandwidth dedicated for cs6 tagged traffic.
Francesco
I your  class-map match-any IA-High.
you will need to add a match on a class-map.
this class map should contain an access list matching tcp port 179 (which is what BGP uses to establish peers and send updates).
Please remember to rate useful posts, by clicking on the stars below.
Hello, so to clarify, do I need to match TCP 179 or can I simply match CS6. I was thinking the simplest method for me would be to add CS6 to the following class map:
match ip dscp cs6 *******
match ip dscp ef
match ip dscp cs4
match ip dscp af41
match ip dscp af42
match ip dscp af43
Francesco
Thank you Francesco, so to confirm, would you agree that doing the following will address the issue:
i.e. to add CS6 to the following class map:
match ip dscp ef
match ip dscp cs4
match ip dscp af41
match ip dscp af42
match ip dscp af43
Yes this will work.
Have you done a tcpdump to confirm that your traffic is already marked with CS6?
Francesco
Thanks, yes a tcpdump confirms that BGP traffic is being marked CS6.
Therefore, would you agree that doing the following will address the issue:
match ip dscp ef
match ip dscp cs4
match ip dscp af41
match ip dscp af42
match ip dscp af43
policy-map QUEUES
class Multi-Media
priority level 1
class IA-Low
class DataTrans
class IA-High
class class-default
policy-map WAN
class class-default
shape peak 30000000
Yes it will solve your issue as it will goes to priority queue
Francesco
