Bgp?
jvicovac88
Community Member
I was wondering if this would work. My task is to advertise routes from my AS and AS 400 and to let AS 400 communicate with other ASs through my AS. Other ASs (three of them - 100, 200 and 300) cannot use my network as a transit network in any other case. Routers connected directly to AS 200 and 300 have the same configuration.
RA(config-router)# neighbor 3.3.3.2 remote-as 100
RA(config-router)# neighbor 3.3.3.2 route-map SET_OUTBOUND_TRAFFIC in
RA(config-router)# neighbor 3.3.3.2 route-map SET_INBOUND_TRAFFIC out
RA(config-router)# neighbor 3.3.3.2 advertise-map ADVERTISE
RA(config-router)# exit
RA(config)# ip as-path access-list 1 permit ^400$
RA(config)# ip as-path access-list 1 permit ^$
RA(config)# route-map SET_OUTBOUND_TRAFFIC permit 10
RA(config-route-map)# set local-preference 200
RA(config-route-map)# exit
RA(config)# route-map ADVERTISE permit 10
RA(config-route-map)# match as-path 1
RA(config)# route-map SET_INBOUND_TRAFFIC permit 10
Thanks.
cadet alain
For this part:
You must do this:
neighbor 3.3.3.2 filter-list 1 out  and same for other neighbors in AS 200 and 300
Indirectly this will prevent all these ASes to use you as transit for other ASes except 400 as your AS_PATH ACL is denying all ASes outbound except 400 and yours.
Regards.
Alain
OK, thank  you.
Best regards,
Jovan.
