%BIT-4-OUTOFRANGE Error
maher0977
Dears,
I have error on the Cisco Catalyst continuously, is this alarm not affected on the switch performance and how can I solve it to kill out it from the switch log buffer?
Jan 10 10:34:24: %BIT-4-OUTOFRANGE: bit 0 is not in the expected range of 1 to 4095
-Traceback= 21A284Cz 100D024z 100D0CCz 1C7882Cz 13D32B8z 160DA44z 1611318z 16116E4z 1543ECCz 1543E74z 1549A5Cz 1549F64z 1543F7Cz 1D28D50z 1D28D28z 1D25614z
Jan 10 10:35:44: %BIT-4-OUTOFRANGE: bit 0 is not in the expected range of 1 to 4095
Switch Ports Model              SW Version            SW Image
*    1 26    ME-3400E-24TS-M    12.2(60)EZ8           ME340x-METROIPACCESSK9-M
Configuration register is 0xF
5 Replies 5
these tracebacks are usually caused by (harmless) bugs.
Can you post the config of your switch ?
It is difficult to send you the whole configuration as it is for my company switch, however; if you want partial configuration for example SNMP, I can send you it or by analyzing commands.
Any assistant for this issue?
you are running version 12.2(60)EZ8 on your switch, try and upgrade to the latest release, 12.2(60)EZ9, and check if the error message disappears.
Here is the link to the download page for the latest release:
https://software.cisco.com/download/release.html?mdfid=282088126&flowid=2674&softwareid=280805680&release=12.2.60-EZ9&relind=AVAILABLE&rellifecycle=ED&reltype=latest
I applied logging discriminator successfully without upgrading the IOS release and then the log is stopped. Has this feature any implications on the switch resources or performance?
