Block a Computer using Layer 3 Switch
Shiva_B
Community Member
We are planning to block certain devices from communicating to a different network segment or different LAN & towards internet using L3 switch / ACL & I am not good with Networking concepts to propose.
I would like to know what are all the possibilities to use this - While the IP address is Dynamic.
Is there an option to block using MAC address?
Is there a way to block a specific protocol keeping dynamic IP in mind.
Any other additional info will be highly helpful to block a computer which cannot be traced.
Deepak Kumar
as you mentioned that there is DHCP server available and users are getting IP through DHCP only. I think Mac ACL is a good solution for you.
Please read the below article:
http://cauew.blogspot.ae/2008/08/vacl-vlan-maps-mac-acl.html
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
5 Replies 5
Seb Rupik
Hi there,
If you know what the MAC address is, why not create a DHCP reservation for the device, which in turn would allow you to create Layer3 ACLs.
cheers,
Seb.
Yes. We have that plan in mind. But we want to keep the device available within the LAN.
A Layer3 ACL would only be applied to the interfaces routing the subnet, ie the router.
Your orginal post requested a way to filter traffic between network segments/ subnets, this would be achieved with a Layer3 ACL.
It would not interfere with intra-VLAN traffic as it is only enforced at the subnet gateways.
cheers,
Seb.
@Seb Rupik thanks for the reply and I agree with you. I mentioned that he can apply MAC ACL in VLAN itself (VACL) and example is also showing same.
Deepak Kumar
Deepak Kumar,
Deepak Kumar
Deepak Kumar
Deepak Kumar,
