Block all traffic based on OUI
jradke
It seems that mac-filtering and PACL's is rather straight forward but its not working on my L2 interface. Port-security works but this is not useful when trying to filter based on OUI.
What am I doing wrong in my config?
Linux box:
Obviously on the same subnet since it has an arp entry, you can also see that it is on a different port since my target box is the only MAC on g1/42.
:arp -an | grep 65.182.XYZ.38
? (65.182.XYZ.38) at 00:11:11:12:1d:62 [ether] on eth0
4948 Switch:
4948-TOP-PRI#sho mac- int g1/42
Unicast Entries
vlan   mac address     type        protocols               port
224    0011.1112.1d62   dynamic ip                    GigabitEthernet1/42
interface GigabitEthernet1/42
description WATSON-PUBLIC
switchport access vlan 224
switchport mode access
logging event link-status
load-interval 30
mac access-group WATSON in
mac access-group WATSON out
spanning-tree portfast
interface Vlan224
description Backbone-Subnet
no ip address
shutdown
end
FAILS to block pings:
mac access-list extended WATSON
permit 0012.1100.0000 0000.00ff.ffff any
deny 0011.1100.0000 0000.00ff.ffff any
deny any any
I may implement this on the VLAN eventually but in simple testing I haven't discovered why this doesn't work on the port level. Ultimately I want to allow this box and deny everything else but I'm testing it by trying to block it first. This is what I should use if the port level mac access-list is working.
permit 0011.1100.0000 0000.00ff.ffff any
cadet alain
MAC ACL applied on a port will not work for IP traffic you'll have to use a VACL instead.
Regards.
Alain
Hello Alain,
Sadly, not even VLAN maps (VACLs) will allow filtering IP traffic based on MAC ACLs. The documentation at
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/secure.html#wp1069162
puts it quite directly:
Access of all non-IP protocols is controlled with a MAC address and an Ethertype using MAC ACLs in VLAN maps. (IP traffic is not controlled by MAC ACLs in VLAN maps.)
To be completely honest, I do not know of any way of filtering IP traffic using MAC ACLs on current Catalysts.
Best regards,
Peter
Hi Peter,
thanks for correcting me, haven't been using VACLs a lot lately and I thought it could work.
Regards.
Alain
Port security works but I can't use a wildcard mask to filter based on OUI.
What solutions are available to me if mac filtering and VACL's are not applicable?
