Block ARP traffic on interface
3em0nd001
Community Member
Hello!
Me shall need block ARP traffic on Interface.
I try follow command:
conf t
int gi0/8
ip access-group 100 in
no arp arpa
I create ACL
access-list 100 permit ip 172.20.0.0 0.0.255.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 172.20.0.0 0.0.255.255
But, if I try
arping to my gi0/8 192.168.1.1 I can take MAC address.
How block ARP on interface?
Mark Malone
Here is a guide on how to block arp at switch level , depending on your model you may support the feature
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3550-series-switches/64844-mac-acl-block-arp.html
It's strangely, but not working. I set in Cisco 2960:
swith(config)#mac access-list extended ARP_Block
swith(config-ext-macl)#no permit host 0040.5a12.b066 any 0x806 0x0
swith(config-ext-macl)#no permit any host 0040.5a12.b066 0x806 0x0
int gi0/8
mac access-group ARP_Block in
And after that arping working.
Me need at host 0040.5a12.b066 blocked all ARP traffic, exclude only ip traffic to network 172.20.0.0 /16
What I'm doing wrong?
If you need to block it as the doc shows you allow the arp in acl but action it to drop , remove your no permit and post all the configuration with the vlan access-map too
Configure
In this section, you are presented with the information to configure the features described in this document.
In order to configure MAC address filtering and apply it to the VLAN interface, you must complete several steps. First, you create the VLAN access maps for each type of traffic that must be filtered. You select a MAC address or range of MAC addresses for blocking. You also need to identify the ARP traffic in the access list. In accordance with RFC 826 leavingcisco.com, an ARP frame uses the Ethernet protocol type of value 0x806. You can filter on this protocol type as interesting traffic for the access list.
  1. In global configuration mode, create a named MAC extended access list with the name ARP_Packet.
    Enter the mac access-list extended ACL_name command and add the host MAC address or addresses that you want to block.
    Switch(config)#mac access-list extended ARP_Packet
    Switch(config-ext-nacl)#permit host 0000.861f.3745 host 0006.5bd8.8c2f 0x806 0x0
    Switch(config-ext-nacl)#end
    Switch(config)#
  2. Enter the vlan access-map map_ name command and the action drop command, which is the action to perform.
    The vlan access-map map_ name command uses the MAC access list that you created to block ARP traffic from the hosts.
    Switch(config)#vlan access-map block_arp 10
    Switch (config-access-map)#action drop
    Switch (config-access-map)#match mac address ARP_Packet
  3. Add an additional line to the same VLAN access map in order to forward the rest of the traffic.
    Switch(config)#vlan access-map block_arp 20
    Switch (config-access-map)#action forward
  4. Choose a VLAN access map and apply it to a VLAN interface.
    Enter the VLAN filter vlan_access_map_name vlan-list vlan_number command.
    Switch(config)#vlan filter block_arp vlan-list 2
