Block traffic between users computers on one VLAN
JakubMalik1782
Frequent Visitor
Frequent Visitor
Dear all,
I have one VLAN for users on Cisco switches 2960 (15 pcs) connected to core switch Nexus 5000.
I need block traffic on VLAN 48 between users computers - all TCP and UDP ports.
I tried command switchport protected it works OK but only locally on one switch and unfortunately feature Private VLAN is not available on our switches.
Is there any way how to solve this ?
Do you have any idea ?
Thank you
Hello
FYI - A routed ACL will not negate access between hosts within the same vlan so a Vlan access list as suggest by @Georg Pauwen would be applicable, but you need to allow access for these hosts to exit it own broadcast domain is need be.
The following example should be applicable:
access-list 100 remark allow vlan48 hosts to default-gateway
access-list 100 permit ip 172.16.48.0 0.0.0.255 host 172.16.48.254
access-list 100 permit ip host 172.16.48.254 172.16.48 0 0.0.0.255
access-list 101 remark deny vlan48 hosts from communicating with each other
access-list 101 permit ip 172.16.48.0 0.0.0.255 172.16.48.0 0.0.0.255
vlan access-map Vl48 10
action forward
match ip address 100
vlan access-map Vl48 20
action drop
match ip address 101
vlan access-map Vl48 99
vlan filter Vl48 vlan-list 48
Kind Regards
Paul
7 Replies 7
Seb Rupik
Hi there,
Why not apply a Layer3 ACL to every access switchport in VLAN48.
Assuming the VLAN48 SVI was 192.168.48.254 /24 it would look like:
ip access-list ext BLOCK_LOCAL_V48
  permit ip 192.168.48.0 0.0.0.255 host 192.168.48.254
  deny ip 192.168.48.0 0.0.0.255 192.168.48.0 0.0.0.255
  permit ip any any
int range gi0/1-24
  ip access-group BLOCK_LOCAL_V48 in
cheers,
Seb.
Georg Pauwen
I wonder if a VACL would work, you would have to apply it to each switch. In the example below, if your VLAN 10 has subnet 192.168.10.0/24, the VACL would deny all intra-VLAN traffic, and allow everything else:
access-list 100 permit ip 192.168.10.0 0.0.0.255 192.168.10.0 0.0.0.255
vlan access-map DENY_INTRA_VLAN 10
action drop
vlan access-map DENY_INTRA_VLAN 20
action forward
vlan filter DENY_INTRA_VLAN vlan-list 10
Hello
action forward
action drop
Kind Regards
Paul
@paul driver , I agree with your router ACL statement but my suggestion is a port ACL implementation which would provide the desired functionality. My current environment doesn't allow me to test it, but it is confirmed by the documentation:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swacl.html#44781
cheers,
Seb.
The idea is that the second statement in the VLAN access map allows everything that does not match intra-Vlan traffic.
I have run a little test in GNS3, with software switches running IOSvL215.2 images, I am not sure though it works on 'real' 2960 switches. Either way, the L2 switches are configured as below (make sure you create the Vlan 10 interface on each switch, it doesn't need an IP address). The ICMP has been added for testing. Anything in Vlan 10 cannot access each other, but access to outside networks is allowed.
access-list 100 permit icmp 192.168.10.0 0.0.0.255 192.168.10.0 0.0.0.255
action drop
action forward
interface Vlan10
Thank you very much !!!
out of curiosity, and since access to addresses outside the VLAN worked even without specifying the default gateway in the VACL, I did some more testing.
I found that you do NOT need to explicitly allow the default gateway in the VACL, the reason being that the traffic to the destination IP address in these packets is not the default gateway address, it is that of the end-device.
That explains why the VACL I originally posted works as well.
