blocking dhcp discover process
CSCO11417382
Hello friends
pcs 172.16.20.0/24 connected to switch IP address 172.16.100.6------switch 172.16.100.1---switch 172.16.100.149----- dhcp server ip 172.16.0.12 connected
I would like to block client discover process of dhcp for computers connected in switch 172.16.100.6 and  other traffic should work fine.
---------- this mean cable connection
8 Replies 8
Hello
access-list 100 deny udp any any eq 67
access-list 100 deny udp any any eq 68
access-list 100 permit up any any
apply the access-list to the L3 interface of the subnet you wish to negate dhcp
intx/x
ip access-group 100 in
io access-group 100 out
Kind Regards
Paul
Thanks for the reply.
I have applied the access list on Layer 3 switch where all our inter vlan routing start from there and want to block specific subnet but it does not work still computer from that below subnet are getting ip addresses from dhcp server and below is my access list.
access-list 102 deny udp 172.16.60.0 0.0.0.255 any eq bootpc
access-list 102 deny udp 172.16.60.0 0.0.0.255 any eq bootps
access-list 102 permit ip any any.
Below  is my logical diagram
Computers subnets 172.16.X.X L2 switch---L3 Switch---Layer2switch----dhcp is located
Please mark helpful posts.
There is a significant logical flaw in your access list.
you are trying to block traffic from an IP subnet. But the purpose of the DHCP query is that it comes from a device that does not yet have an IP address. So you will never see a DHCP request with source 172.16.60. The suggestions that you need to deny udp any any are correct.
Rick
Rick
Reading through my response I realize that part of it was not well written. Rather than saying that the ACL should deny udp any any I should have either said deny should specify any any instead of specifying the source subnet or I should have been more complete and said deny udp any any eq bootpc or bootps.
Rick
Rick
pieterh
a simple way to go is to enable dhcp-snooping and NOT trust any other link for dhcp
dhcp discover packets wil not be blocked , but response is not returned, so the discovery will not complete
Hello
This will not stop a client from receiving dhcp that isn’t suppose to because you need to trust the same uplink that sources dhcp for other clients that do require it
Kind Regards
Paul
