Blocking RIP updates ?
philipbarker
Is there a way to block RIP updates 'outbound' on a router interface ?
I realise that it is probably better to block them 'inbound' to save unnecessary processing. But I cannot get outbound to work. I am using the following acl :
access-list 100 deny udp any any eq rip
int e0
ip access-group 100 out
Phil.
Phil
Apologies Phil, didn't mean to patronise you.
No this won't work because an access-list applied outbound on an interface does not stop packets sourced by the router itself.
Jon
Jon Marshall
Hi Phil
You can use the "passive-interface" command to achieve this ie. from Cisco doc
For RIP and IGRP, the passive interface command stops the router from sending updates to a particular neighbor, but the router continues to listen and use routing updates from that neighbor;
Full link
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080208748.shtml
Jon
Thanks John,
I understand the passive-interface operation. Can you confirm if it is or isn't possible though to filter the udp broadcasts 'outbound' a router interface ?
Phil.
Phil
Jon
Hi John,
No need to apologise. I am just trying to do things in as many different ways as possible so that my options remain open.
Phil.
