Blocking traffic in single VLAN on port level
ajay-pawar
Hi ,
      We have Cisco 3750 switch . Need to block traffic within single VLAN on TCP port 1443 .
      Please help.
Thanks & Regards
Ajay
glen.grant
   Write an ACL for the layer 3 SVI  for that vlan that will block the port you are looking to block.
Matthew Blanshard
Hello Ajay,
Sounds you a VACL would be the best option here for you.  Here's the configuration guide on VACL's:
http://tools.cisco.com/squish/fF099
Here's an example of how you would configure this:
Switch(config)# ip access-list extended no_1443
Switch(config-ext-nacl)# permit tcp any any eq 1443
Switch(config-ext-nacl)# exit
Switch(config)#ip access-list extended permit_any
Switch(config-ext-nacl)# permit ip any any
Switch(config)# vlan access-map block_1443 10
Switch(config-access-map)# match ip address no_1443
Switch(config-access-map)# action drop
Switch(config-access-map)# exit
Switch(config)# vlan access-map block_1443 20
Switch(config-access-map)# match ip address permit_any
Switch(config-access-map)# action forward
Switch(config)# vlan filter block_1443
This will block all packets destined to tcp port 1443 within the vlan.  If you wanted to block tcp traffic sourced from that port you would add "permit tcp any eq 1443 any" to the access-list no_1443.
HTH,
Matt
