blocking UDP port on the 2960 switch
lunarsystems
Hello
I need to block udp port 1443 to 15 devices. The network is setup at the moment with an ACL list. Apparently this is not working and a VLAN configuration has been suggested.
Can anyone suggest a configuration because I have read that the lower end CISCO switches cannotselectively apply an ACL per VLAN.
Andrei
amdil
Andrei,
You can use ACL per interface and per VLAN too. Please provide more details.
