Blocking Unwanted website using CLI on Cisco 1941
prompt2k2
Level 2
Level 2
What are the command for blocking unwanted URL on my network, for example, I want to block www.facebook.com on my network, can anyone help me with the commands.
I will also like to know how to add security to the network, please note the router is NOT a wireless router.
Thank you in anticipation.
cadet alain
You'll have to use MQC and NBAR or used Cisco zone based firewall.
I'll show you with MQC and NBAR:
class-map match-any BLOCKED
match protocol http host "*facebook.com"
policy-map BLOCK
class BLOCKED
drop
interface vlan 1
service-policy input BLOCK
Regards.
Alain
26 Replies 26
cadet alain
policy-map BLOCK
class BLOCKED
drop
interface vlan 1
Regards.
Alain
Hi Alain,
Thank you very much.
I wish I could get a one-on-one chat with you to resolve some minor issues, will be highly appreciated.
Thank you.
no problem send me a PM.
Regards.
Alain
Hi Alain,
I am a regular visitor and a member of Cisco support forum. I have seen many of your replies to users Query. You are doing a great Job....
Roopesh
Hi Rupesh,
Regards.
Alain
Hi Paul,
send me all details by PM or mail. I'm only able to do this in the evening post 8 PM CET time +2
Regards.
Alain
Hello cadet,
is there available any option for "blocking unwanted URL" with HTTPS traffic with "only" IOS ?
I think it shall also work for HTTPS.The only thing won't be able to do is inspect the payload though as it is encrypted.
Regards.
Alain
Hello Cadet,
no this configuration do NOT work for the httpS traffic (you can only block http traffic).
Hi roberto,
thanks for the info, i hadn't tried it before and couldn't find the information so that's why i was supposing it would work.
I found this:
HTTPS Establishes an underlying SSL conenction before any HTTP data is   transferred. This ensures that all URL data (with the exception of   hostname, which is used to establish the connection) is carried solely   within this encrypted connection and is protected from   man-in-the-middle attacks in the same way that any HTTPS data is.
So only the host field is not encrypted, I learned something new today.
Regards.
Alain
I presume that:
1st) on IOS it is NOT possible to filter FQDN/URL HTTPS traffic
1 the DNS query or DNS-SEC answer
2 the Client Hello
TLS handshake occurs long before any HTTP traffic.
http://www.moserware.com/2009/06/first-few-milliseconds-of-https.html
2nd) on latest ASA os it's "possible" using "FQDN access-lists":
https://supportforums.cisco.com/docs/DOC-17014
3rd) using latest ASA CX module
Q.
Can ASA CX decrypt TLS/SSL or SSH traffic for inspection?
A. At initial release, ASA CX will be able to decrypt TLS/SSL. Decryption of SSH will be enabled in a future release. ASA CX will decrypt HTTPS traffic to identify encrypted applications. This decryption can be intelligently performed based on rich context parameters such as source (user, subnet), destination (FQDN, web category, subnet), and reputation of the destination servers.
Hi Alain,
Is there an exception for this rule? for instance, I have blocked the "FACEBOOK.COM" site, but I want to allow an individual ip, (10.10.10.23) to access the page FACEBOOK.com, how do I do that?
Thank you
try this:
ip access-list extended block-exemption
permit ip host 10.10.10.23 any
class-map match-all BLOCK_EXEMPTION
match  access-group name block-exemption
class-map match-all BLOCKED
match not class-map BLOCK-EXEMPTION
policy-map BLOCK
class BLOCKED
drop
interface vlan 1
Regards.
Alain
Hi Alain,
I config this router fine on saturday, but switching it on, my PCs cannot logon to the network, they are all point to "unidentified network" what else have I done wrong?
income(config)#exit
income#sh run
Building configuration...
Current configuration : 3490 bytes
! Last configuration change at 08:14:49 UTC Mon Oct 8 2012
! NVRAM config last updated at 08:10:29 UTC Mon Oct 8 2012
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname income
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 $1$K/Wt$MOaWnBNOE9rLay.m8Sh4a.
enable password 7 151B050F0B272E76
aaa new-model
aaa authentication login default local
aaa authentication enable default none
aaa authentication ppp default local
aaa session-id common
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.39
ip dhcp pool users
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 217.117.0.38 10.10.10.244
no ip bootp server
ip domain name incomeelectrix
ip name-server 217.117.0.38
ip name-server 10.10.10.244
license udi pid CISCO1941/K9 sn FCZ1633716L
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
username income privilege 15 secret 4 HSyp0yWKpXLGNBvuMAwswNaIjZOwIZdQsd4T3M2hSo
A
redundancy
ip tcp synwait-time 10
match protocol http host "*youtube.com"
policy-map BLOCK
class BLOCKED
  drop
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
interface GigabitEthernet0/0
description $ES_LAN$$ETH-LAN$
ip address 10.10.10.1 255.255.255.0
ip helper-address 10.10.10.1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description $ES_WAN$$ETH-WAN$
ip address 41.75.205.190 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
no mop enabled
router eigrp 109
network 10.0.0.0
network 41.0.0.0
router rip
version 2
network 10.0.0.0
network 41.0.0.0
no auto-summary
ip default-gateway 41.75.205.189
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool overld 41.75.205.190 41.75.205.190 prefix-length 24
ip nat inside source list 7 pool overld overload
ip route 0.0.0.0 0.0.0.0 41.75.205.189
logging trap debugging
access-list 7 permit 10.10.10.0 0.0.0.255
access-list 199 permit icmp any any
no cdp run
snmp-server community public RO
control-plane
banner login ^CWelcome to Incomeelectrix.^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
password 7 11001706181F0E5D
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
end
income#
