Blocking Unwanted website using CLI on Cisco 1941
prompt2k2
What are the command for blocking unwanted URL on my network, for example, I want to block www.facebook.com on my network, can anyone help me with the commands.
I will also like to know how to add security to the network, please note the router is NOT a wireless router.
Thank you in anticipation.
26 Replies 26
Could you do this:
conf t
ip bootp server
int g0/0
no ip helper-address 10.10.10.1
Regards.
Alain
Hi Alain,
Done, but still nothing happened
income(config)#ip bootp server
income(config)#int gig0/0
income(config-if)#no ip helper-address 10.10.10.1
income(config-if)#end
income#copy running-config startup-config
Destination filename [startup-config]?
Building configuration...
[OK]
income#sh run
Current configuration : 3439 bytes
! Last configuration change at 08:48:50 UTC Mon Oct 8 2012
! NVRAM config last updated at 08:49:06 UTC Mon Oct 8 2012
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname income
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 $1$K/Wt$MOaWnBNOE9rLay.m8Sh4a.
enable password 7 151B050F0B272E76
aaa new-model
aaa authentication login default none
aaa authentication enable default none
aaa authentication ppp default none
aaa session-id common
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.39
ip dhcp pool users
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 217.117.0.38 10.10.10.244
ip domain name incomeelectrix
ip name-server 217.117.0.38
ip name-server 10.10.10.244
license udi pid CISCO1941/K9 sn FCZ1633716L
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
username income privilege 15 secret 4 HSyp0yWKpXLGNBvuMAwswNaIjZOwIZdQsd4T3M2hSo
A
redundancy
ip tcp synwait-time 10
class-map match-any BLOCKED
match protocol http host "*facebook.com"
match protocol http host "*youtube.com"
policy-map BLOCK
class BLOCKED
  drop
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
interface GigabitEthernet0/0
description $ES_LAN$$ETH-LAN$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
service-policy input BLOCK
interface GigabitEthernet0/1
description $ES_WAN$$ETH-WAN$
ip address 41.75.205.190 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
no mop enabled
router eigrp 109
network 10.0.0.0
network 41.0.0.0
router rip
version 2
network 10.0.0.0
network 41.0.0.0
no auto-summary
ip default-gateway 41.75.205.189
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool overld 41.75.205.190 41.75.205.190 prefix-length 24
ip nat inside source list 7 pool overld overload
ip route 0.0.0.0 0.0.0.0 41.75.205.189
logging trap debugging
access-list 7 permit 10.10.10.0 0.0.0.255
access-list 199 permit icmp any any
no cdp run
snmp-server community public RO
control-plane
banner login ^CWelcome to Incomeelectrix.^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
password 7 11001706181F0E5D
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
end
income#
has your router been restarted since you had the problem ?
Can you do debug ip dhcp server packet  and then one one host: ipconfig/release then ipconfig/renew
and post output of the log.
Regards.
Alain
Hi Alain,
I also noticed something, the router is connected to a switch, every system I connected to the switch directly using a cable can access the internet, but other systems connected via a wireless access points (the access points are connected to same switch with cables) cannot access the internet. This was not the case before, I seem to be doing some authentication or authorisation configuration wrong.
one stuuf you should do also is disable dhcp conflict logging as you have not configured any dhcp database.
conf t
no ip dhcp conflict logging
Concerning the wireless devices , we need more infos as we only got the router running config here.
Do they get a dhcp ip address?
Regards.
Alain
They are configured to get IP addresses from the router, they have been working before now, so I doubt the problem is from the wireless access points.
I have restarted the router. still no joy.
did you configure no ip dhcp conflict-logging ?
post the debug ip dhcp server packet output when trying to renew on a wireless host.
post also the output from:
sh ip dhcp binding
sh ip dhcp pool users
Regards.
Alain
income#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                    Hardware address/
                    User name
10.10.10.40         01cc.b255.badb.8c       Oct 09 2012 09:13 AM    Automatic
10.10.10.41         01a0.4e04.0a16.e5       Oct 09 2012 09:15 AM    Automatic
10.10.10.45         01cc.b255.badd.22       Oct 09 2012 09:27 AM    Automatic
10.10.10.46         015c.95ae.ea8c.31       Oct 09 2012 09:19 AM    Automatic
10.10.10.47         01e0.b9a5.cdaa.a3       Oct 09 2012 09:27 AM    Automatic
10.10.10.48         0100.26c6.770e.64       Oct 09 2012 09:29 AM    Automatic
10.10.10.49         0100.24be.c0f2.48       Oct 09 2012 09:29 AM    Automatic
10.10.10.51         0100.23d3.0115.df       Oct 09 2012 09:33 AM    Automatic
10.10.10.52         0100.026f.4c86.2d       Oct 09 2012 09:33 AM    Automatic
income#
income#sh ip dhcp pool users
Pool users :
Utilization mark (high/low)    : 100 / 0
Subnet size (first/next)       : 0 / 0
Total addresses                : 254
Leased addresses               : 9
Pending event                  : none
1 subnet is currently in the pool :
Current index        IP address range                    Leased addresses
10.10.10.53          10.10.10.1       - 10.10.10.254      9
income#
ok what about the debug output when renewing ip from wireless device ?
Regards.
Alain
Hi Alain,
Each PC were able to do the ipconfig /release and /renew command, like I said earlier, I realised they can access the internet when connected to the switch using a cable, but will not identify a network when connected to the Access Points.
I had to reconfigure each Access Points again with a newer SSID for other systems to be able to connect to the Internet.
At this moment, I can connect them using 2 AP, while I think I will reconfigure the other 2 APs.
With this capacity, I can manage the systems to work, while I sort out the pending issues.
I will send you a PM for the network as initially discussed, so you can help take a look.
Cheers.
does not work
dear cadet,
it's does not work out.
