blocking web trafic
yokaso007
Community Member
Hi, i would like to block all Web Trafic for my LAN, and i using my switch Cisco 2960.
i tried to do that with access list :
deny tcp any 192.168.1.0  0.0.0.255 eq 80
but it don't work, can you give me an idea ?
Hi Kiees,
Do you intend to prevent web traffic to go to servers on this LAN or web traffic to be initiated from the LAN.
if the former than the ACL would work, assuming that it was applied outbound on the interface.
thank u , i will check it again
