Bond two VDSL connections with dual EHWIC-VA-DSL-A?
WStoffel1
Can it be done?  I have a Cisco 1921 with two of these cards.  Thanks to
Mithun Puttamadaiah on another post i got the config going.  Theres a surprising lack of documentation on this card.
But I do have 2 vdsl lines coming into this facility, so how do i go about bonding them together?
My first assumption is i need to configure ATM.
Any ideas?
Hello.
What are the services provider sells you with the links?
Is it just simple Internet access?
Have I understood you correctly, that:
  • you have different set of credentials per link;
  • each link has different IP-address assigned;
  • the service (links) are provided by some provider;
  • you are using the links for Internet access.
If so, then to utilize both links you need to ask your provider to bundle the links together, into single L3 interface.
PS: your diagram has no port names, so I don't understand what is the role for E0/1/0 and E0/0/0.
PS2: why do you use dialer-pool 1 and 2 on both ATM0/0/0 and ATM0/1/0? Why do you use dialer-pool on Ethernet interfaces?
PS3: if you are not sure about configuration, then for implementation it worth to have anybody on site with 3G modem to allow you remote access.
Hello.
Could you share your current configuration and interconnection diagram?
If you are using ppp encapsulation and both lines are terminated on a single remote device, you could use ppp multilink. Otherwise you may use equal-path load balancing with capable IGP.
Sure thing.  This is just a config that I pieced together.  No idea what works or doesn't since it needs to be shipped to the remote location.  But this is for starters at least....I know if have the Bell.ca modems in the attached pic, i'm thinking they will actually be removed.  I'd rather come right from the wall jacks to the router on the outside.  Gig 0/0 will patch over to X3 on the Sonicwall, and X0 will patch over to the switch.
I still need to lock it down, but right now I'm more interested in just getting an internet connection since I'll be configuring the final version remotely with no IT support on the remote end.
DPAI#sh run
Building configuration...
Current configuration : 2786 bytes
! Last configuration change at 17:37:54 UTC Tue Feb 4 2014
version 15.2
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname DPAI
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
no ip source-route
ip cef
license udi pid CISCO1921/K9 sn FGL1532220J
controller VDSL 0/0/0
operating mode vdsl2
sra
controller VDSL 0/1/0
sra
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
ip nat outside
no atm ilmi-keepalive
pvc 0/35
  pppoe-client dial-pool-number 2
  pppoe-client dial-pool-number 1
interface Ethernet0/0/0
no ip address
pppoe enable group global
interface ATM0/1/0
no ip address
ip nat outside
pvc 8/35
interface Ethernet0/1/0
no ip address
interface Dialer1
mtu 1460
ip address 70.55.236.225 255.255.255.0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callout
ppp chap hostname txxxx@bellnet.ca
ppp chap password 7 044F5B515E725E4B0E
ppp pap sent-username txxxx@bellnet.ca password 7 044F5B515E725E4B0E59
interface Dialer2
mtu 1460
ip address 76.70.1.69 255.255.255.0
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ppp chap password 7 03100B5D5F5C334949
ppp pap sent-username txxxx@bellnet.ca password 7 09581E5F405605170C4C
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat source static tcp 192.168.1.253 4433 interface GigabitEthernet0/0 4433
ip nat inside source list 99 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 99 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
And yes, the dialer info, ATM, pretty much anything with the VA-DSL-A card I was pretty much winging.  If you see anything that's not needed/wrong/incomplete or just plain nonsensical, by all means let me know.  It's connecting to 2 VDSL lines in Ontario and Bell Canada does not support this config.
Thanks again.
Hello.
Actually you helped more than you know right now...yes, set of creds per link and different IP's....what i really needed to know was WHO was supposed to bond them.  This was sold to our customer completely incorrectly and I'm just trying to triage the situation.  But I have very very limited experience with DSL......
I have more than i need configured simply because I had the router in my posession.  It has now been shipped to the site.  I will have a non-IT person that will plug it in, hook up the console cable to a laptop, and use a 3rd internet connection that I'll be able to remote in and configure, change, troubleshoot, and debug this setup.
So, to PS2 above, I'm going to be using ATM, ethernet was done only becaue the config allowed me to
But I was a little confused, admittedly, on the dialer pools as I thought each dialer had to be in it's own pool.  That will be the first change I make on the config.
So thank you, very much appreciated.  We'll see next week how it goes when it gets all hooked up.
