boot bootldr, boot bootstrap and boot system command?
nitass
Hello All,
Could anyone please explain me what the “boot bootldr” and “boot bootstrap” are? And how do they different from the “boot system” command?
I did not understand the description of these commands in the Cisco command reference document.
Thanks a lot,
Nitass
amit-singh
Level 8
Level 8
Hi Nitass.
Boot system is used to specify the system image that loads at startup i.e the full IOS image that system will load.
boot bootldr command is used to specified a boot loader image which is an image with only booting featues and few limited commands, this image is like a safe mode for the system where we fall back on if system is unable to boot from main image.
bootstrap is the minimum software that is required to recongnize and run the hardware. It comes both in software and hardwares with the software.Like in cat 6K on Sup's is a special hardware with an image on it.
HTH,
-amit singh
6 Replies 6
amit-singh
Level 8
Level 8
Hi Nitass.
HTH,
-amit singh
Hi amit-singh,
Thanks for reply.
Do you know where I can download the boot loader and boot strap software image?
I have tried to find it at download page and just saw only the ROMMON upgrade software image. Is it as boot strap software image?
Thank you very much,
Nitass
Could you please let me know the hardware you are using ???
regards,
-amit singh
Hi amit singh,
Thanks for reply. My hardware is Catalyst 4507R.
Thanks a lot,
Nitass
There is no boot loader image for your Sup on 4500's. You can upgrade the rommon i.e bootstrap and its the promupgrade image avaialable when u download the IOS from CCo for 4500's.
HTH,
-amit singh
Hi amit-singh,
Ok, thank you very much.
Thanks a lot,
Nitass
