Boot Flash Error Cisco 3524XL
haryl8723
Every time I delete the directory flash and reinstall it, I get an error:
Error loading "flash:c2950-i6q4l2-mz.121-12c.EA1.bin"
Interrupt within 5 seconds to abort boot process.
That is the message I get. It's set to NO manual boot, but it keeps making me manualoly boot it. I am at a loss, I've done 3 switches and they all keep doing the same thing. Could someone help me out?
2 Accepted Solutions
Peter Paluch
Hi Haryl,
This looks like the bootloader remembers the last statically set name and location of the IOS, and that has changed for whatever reason. I suppose your switch eventually boots so when it does, enter the show flash: or dir flash: command, find out the exact name and location of the current IOS image name in your IOS, and then enter the global configuration mode and enter the following command:
boot system flash:NAME-OF-THE-IMAGE
Verify your setting after exiting the configuration mode using the show boot command, and try reloading the switch.
One question: how come your switch tries to boot a 2950 series image if your switch is a 3524XL?
Best regards,
Peter
c3500XL-c3h2s-mz-120.5-XU.bin
XU???  Could you try a newer IOS?  Like the WC17?
6 Replies 6
Leo Laohoo
Hold on ...
You have a 3500XL so why is it loading an IOS for a 2950?
Peter Paluch
Hi Haryl,
Best regards,
Peter
I copied the wrong one, I messing with something else also.
dir_flash:c3500XL-c3h2s-mz-120.5-XU.bin
When I do a boot flash:filename it boots immediately, but I'll try that.
I changed it to the WC17, so I could atleast use the "do" command lol Thx much
that worked assumly thx much
