boot system and config register commands
sarahr202
Level 5
Level 5
HI every body!
If we use " config register" and " boot system" command, which one takes precedence over the other? for example config register specify the different location for ios to load and boot system specify different location for ios to load.
Thanks a lot!
Edison Ortiz
config-register is executed before boot system command.
HTH,
__
Edison.
JamesLuther
Level 3
Level 3
Boot system tells the router which IOS image to load.
config-register tells the router how to boot. ie you can set the router to go straight to eprom, boot using the startup-config or boot ignoring the startup-config etc etc.
Try reading these links
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml
http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf010.html
or you can find out about any cisco commands by googling someting like
"config-register command reference site:cisco.com"
Thanks a lot James!
By specifying the location, type of ios is also specified automatically. How?
ROM has limited function of ios type
flash has fully functional ios
So when i use the command" boot system rom"
it will tell router the location for ios. Since ROM holds only limited functional ios, therefore type of ios is also specified implicitly .
Thanks a lot!
Edison Ortiz
HTH,
__
Edison.
Thanks Edison!
