bootflash question
schoychidl
Community Member
I am a Cisco rookie with very little Cisco experience.  We have a Catalyst 4506-e switch that boots occasionally reboots into ROMmon mode (while in ROMmon mode, manually booting to the correct bootflash file will result in a proper boot)..  All other 4506-e's boot fine.  Doing basic investigation and compairing results of show run-config gives these results:
Good switches:
service sequence-numbers
hostname xxxxxxxx
boot-start-marker
boot-end-marker
logging buffered
Bad switch:
hostname xxxxxxxxx
boot-start-marker
boot bootstrap bootflash:
boot system flash bootflash:cat4500e-ipbasek9-mz.122-53.sg2.bin
boot system flash bootslash:cat4500e-ipbasek9-mz.122-53.SG.bin
boot system flash bootflash:cat4500e-ipbasek9-mz.122-53.SG2.bin
boot bootldr bootflash:cat4500e-ipbasek9-mz.122-53.SG2.bin
boot-end-marker
logging buffered
The correct bootflash: is in bold above.
Also, dir bootflash: gives these results:
Good switches:
Directory of bootflash:/
    6  -rw-    24678948  May 18 2010 07:01:52 -04:00  cat4500e-ipbasek9-mz.122-53.SG2.bin
128282624 bytes total (96129024 bytes free)
Bad switch
    6  -rw-       34033   Dec 8 2011 11:21:34 -05:00  10.14.2.14
    7  -rw-    24678948   Aug 2 2012 11:21:58 -04:00  cat4500e-ipbasek9-mz.122-53.SG2.bin
    8  -rw-    24678948  May 18 2010 07:09:54 -04:00  cat4500e-ipbasek9-mz.122-53.SG2OLD.bin
128282624 bytes total (71397376 bytes free)
Does this information help diagnose why the bad switch will reboot in ROMmon mode?  If you are able to provide help, I would sincerely appreciate step-by-step instructions for any fix.  I'm still learning my way around the Cisco environment.
Arumugam Muthaiah
The switch could wind up in ROMmon mode due to these reason
  • A switch reload or crash after the image was corrupted or deleted
  • The Compact Flash which holds the system image has been removed
  • The configuration register has been changed incorrectly. The configuration register value of 0x0 always brings the switch to ROMmon mode. The typical configuration register is 0x2102, with the boot system flash command pointing to the system image to load
  • The boot variable is incorrect, but a valid image is still present
Suggestion:
  • Issue the show bootvar command to check the current boot variable
Switch#show bootvar
BOOT variable = bootflash:cat4000-is-mz.121-8a.Ew,1
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
  • Remove the existing incorrect boot variable and add the correct one. Issue the configure terminal command in order to do this.
Switch#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#no boot system flash bootflash:cat4500e-ipbasek9-mz.122-53.sg2.bin
Switch(config)#no boot system flash bootslash:cat4500e-ipbasek9-mz.122-53.SG.bin
Switch(config)#boot system flash bootflash:cat4500e-ipbasek9-mz.122-53.SG2.bin
Switch(config)#end
  • Save the configuration from running to startup, by issuing the write memory command.
Switch#write memory
Building configuration...
Compressed configuration from 4359 bytes to 1730 bytes[OK]
Switch#
  • Check the boot variable again to make sure it is set properly so that the switch boots up the correct system file on the next reboot. Issue the show bootvar command in order to do this.
Switch#show bootvar
BOOT variable = bootflash:cat4500e-ipbasek9-mz.122-53.SG2.bin
Refer:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_example09186a0080094ecf.shtml
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Hello Aru,
Thanks for the reply and the help.  I followed your instructions explicitly.  Here's what I get at show bootvar:
show bootvar
BOOT variable = bootflash:cat4500e-ipbasek9-mz.122-53.SG2.bin,1;
BOOTLDR variable = bootflash:cat4500e-ipbasek9-mz.122-53.SG2.bin
Configuration register is 0x2101
Any issue with this being different that what you expected?
Thanks for the help!
Thanks for your kind response. If you see that the configuration register is set as 0x2101. Usually from the factory the config register is 0x2101 which means it loads the first image it finds in flash regardless of the boot statement you try to use
In your case, the switch is ignoring your boot statement
When you do a "sh bootflash: the image that is on top is the one that will load with a 0x2101 register.
Suggestion:
Please change the config register as 0x2102 which will use the image you specify in the boot statement
Refer:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml
Aru
Thank you Aru,
That fixed my issue today so thank you for posting this easy to follow solution!
