02-17-2012 02:59 PM - edited 03-07-2019 05:00 AM
After reading the borderless campus qos recommendation for this document, I'm a bit confused by the settings on
on the classification of voip RTP traffic.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/Borderless_Campus_Network_1.0/BN_Campus_QoS.html
cr22-4507-LB(config)#ip access-list extended MULTIMEDIA-CONFERENCING
cr22-4507-LB(config-ext-nacl)# remark RTP
cr22-4507-LB(config-ext-nacl)# permit udp any any range 16384 32767
cr22-4507-LB(config-ext-nacl)#ip access-list extended SIGNALING
cr22-4507-LB(config-ext-nacl)# remark SCCP
cr22-4507-LB(config-ext-nacl)# permit tcp any any range 2000 2002
cr22-4507-LB(config-ext-nacl)# remark SIP
cr22-4507-LB(config-ext-nacl)# permit tcp any any range 5060 5061
cr22-4507-LB(config-ext-nacl)# permit udp any any range 5060 5061
Class-map
cr22-4507-LB(config)#class-map match-all VVLAN-SIGNALINGcr22-4507-LB(config-cmap)# match ip dscp cs3cr22-4507-LB(config-cmap)#class-map match-all VVLAN-VOIPcr22-4507-LB(config-cmap)# match ip dscp efcr22-4507-LB(config-cmap)#class-map match-all MULTIMEDIA-CONFERENCINGcr22-4507-LB(config-cmap)# match access-group name MULTIMEDIA-CONFERENCINGcr22-4507-LB(config-cmap)#class-map match-all SIGNALINGcr22-4507-LB(config-cmap)# match access-group name SIGNALING.....
policingcr24-3750-LB(config)#policy-map Phone+PC-Policycr24-3750-LB(config-pmap)# class VVLAN-VOIPcr24-3750-LB(config-pmap-c)# police 128000 8000 exceed-action dropcr24-3750-LB(config-pmap-c)# class VVLAN-SIGNALINGcr24-3750-LB(config-pmap-c)# police 32000 8000 exceed-action dropcr24-3750-LB(config-pmap-c)# class MULTIMEDIA-CONFERENCINGcr24-3750-LB(config-pmap-c)# police 5000000 8000 exceed-action dropcr24-3750-LB(config-pmap-c)# class SIGNALINGcr24-3750-LB(config-pmap-c)# police 32000 8000 exceed-action drop....
marking
cr22-3750-LB(config)#policy-map Phone+PC-Policycr22-3750-LB(config-pmap)# class VVLAN-VOIPcr22-3750-LB(config-pmap-c)# set dscp efcr22-3750-LB(config-pmap-c)# class VVLAN-SIGNALINGcr22-3750-LB(config-pmap-c)# set dscp cs3cr22-3750-LB(config-pmap-c)# class MULTIMEDIA-CONFERENCINGcr22-3750-LB(config-pmap-c)# set dscp af41cr22-3750-LB(config-pmap-c)# class SIGNALINGcr22-3750-LB(config-pmap-c)# set dscp cs3cr22-3750-LB(config-pmap-c)# class TRANSACTIONAL-DATAcr22-3750-LB(config-pmap-c)# set dscp af21cr22-3750-LB(config-pmap-c)# class BULK-DATAcr22-3750-LB(config-pmap-c)# set dscp af11cr22-3750-LB(config-pmap-c)# class SCAVENGERcr22-3750-LB(config-pmap-c)# set dscp cs1cr22-3750-LB(config-pmap-c)# class DEFAULTcr22-3750-LB(config-pmap-c)# set dscp default
My questions are
1. Will this setting put the RTP traffic from a softphone behind the Cisco IP phone into theMULTIMEDIA-CONFERENCING class, which was set to the DSCP af41 instead of EF eventually?
2. What if the IP phone on this switchport is a non-cisco IP phone. (e.g. Avaya IP Phone.)
if the port is still configured as a conditional-trust port, will the same thing happen that the Avaya ip phone's
voip traffic will be set to default dscp value at the ingress first before it was classified by class
MULTIMEDIA-CONFERENCING and set to DSCP af41 instead of ef?
Is there any limitation of this settings?
Kevin
02-17-2012 04:55 PM
1) This policy would be applied to your switch port as an inbound policy on ingress.
The data will arrive serially at the port and each IP packet will inspected and
treated as per the policy.
The switchport has not control over the order of packet arrival. Therfore the ingress
packets will be treated in a first come first served fashion no matter whether they
are from the actual phone or any device behind it.
2) The AVAYA phone will not be sending rtp packet with udp port range 16384-32767 as these
are Cisco IPT values but can be matched as DHCP EF (46). For signalling it is best to ask
the AVAYA switch person to change thesignalling DSCP to CS3 (24) for traversing Cisco network kit.
This allows you to either just trust the DSCP
on a port or use the policy map.
interface fas 0/21
desc *** AVAYA PHONE & PC ***
mls qos trust dscp
queue-set 1
srr-queue bandwidth share 1 30 35 5
priority-queue out
The bandwidths should be similar between Cisco & Avaya phones.
Alex
02-17-2012 08:06 PM
Thank you acampbell for your answers.
Actually my question is more on the marking part.
let's say a PC behind a 3750 switch port, so switchport can't trust the DSCP setting from the PC.
Then CIPC rtp stream DSCP will be set to default.
Am I correct that once the CIPC RTP traffic hit the ingress, it will be caught by MULTIMEDIA-CONFERENCING class instead of
VVLAN-VOIP class and the DSCP will be set to AF41 while DSCP EF is preferred setting for RTP?
