BPDU filter is enabled internally
paulstone80
Level 7
Level 7
When I look at the output from 'show spanning-tree interface gi1/0/1 detail', I can see that the interface has 'BPDU filter enabled internally'.
There are no BPDU filter commands enabled on the switch, either globally or at an interface level, so I wondered what this message refers to?
Paul
HTH Paul ****Please rate useful posts****
maybe that is a normal output in stacked setup..what IOS version do you use? How is the other coresponding switchport configured.
like we see, BPDUs will be sent and received, so the BPDU-Filter is not working...
I found a post, where in the default config, it looks the same and BPUD Filter was not enabled.
http://networkingnerd.net/2010/11/23/bluntly-bpduthe-redux
9 Replies 9
Sebastian Helmer
Level 10
Level 10
In the default config, BPDU-Filter is off, check if the "spanning-tree bpdufilter enable" command is used on the interface base. BPDU filter is only a interface command.
Hi Sebastian,
There are no spanning-tree commands set at the interface level.
interface GigabitEthernet1/0/1
description ***Uplink to core***
switchport mode trunk
load-interval 30
end
But the spanning-tree detail shows BPDU filter is enabled internally
Port 1 (GigabitEthernet1/0/1) of VLAN0001 is forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.1.
   Designated root has priority 32769, address 000a.b849.f980
   Designated bridge has priority 32769, address 000a.b849.f980
   Designated port id is 128.1, designated path cost 0
   Timers: message age 2, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   Link type is point-to-point by default
   Bpdu filter is enabled internally
   BPDU: sent 5, received 37473
Paul
I'm sorry there is a global command too...
 spanning-tree portfast bpdufilter default
you can check that with:
 show spanning-tree summary totals
if that all did not help, did you every try to disable it per inerteface?
spanning-tree bpdufilter disable
Hi Sebastian,
The global command spanning-tree portfast bpdufilter enable is not in the global configuration either.
I'm not going to attempt to disable the bpdu filter because these switches are in a production environment.
My question was why I see BPDU filter is enabled internally when there are no BPDU filtering commands in the configuration?
Paul
HI Paul,
Can you do the following command on the interface in question?
show spanning-tree interface ***** detail
You should se output similar to this:
                     spanning-tree interface f1/0/1 detail
Port 3 (FastEthernet1/0/1) of VLAN0150 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.3.
   Designated root has priority 4246, address 0cd9.9669.2e00
   Designated bridge has priority 4246, address 0cd9.9669.2e00
   Designated port id is 128.3, designated path cost 0
   Timers: message age 0, forward delay 0, hold 0
   The port is in the portfast mode
   Bpdu guard is enabled
   BPDU: sent 0, received 0 WH-ATL-3750V2#sh spanning-tree interface f1/0/1 detail
This will tell you with certainty if BPDUfilter is really on.
Thanks!
Nick
Nick Bonifacio CCIE #38473
Hi Nick,
Output below:
Switch#sh spanning-tree interface gi1/0/1 detail
   BPDU: sent 5, received 43729
I think the output suggests that BPDU is not enabled within the configuration, but it is enabled on some internal level. This switch is part of a 3750 stack if that makes any difference?
Paul
can you check if BPDU filter is enabled under port-channel? this can reflect on interfaces as well
I checked the output against some other non-stacked 3750's, and the non-stacked switches don't show BDPU filter enabled internally, so i'm sticking with it being due to the switches being stacked unless i'm told otherwise!
Thanks for your input guys
