BPDU guard
The_guroo_2
Level 2
Level 2
gusy whats the difference between the following command
spanning-tree bpdu guard enable
spanning-tree bpdu guard default
thanks and have a good new year
crow930us
Level 3
Level 3
By default bpdu guard is disabled (default). The enable option turns it on.
Cisco docs are here: Spanning Tree PortFast BPDU Guard Enhancement http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a008009482f.shtml
smothuku
Level 7
Level 7
Hi ,
Wish U A HAPPY NEW YEAR.
BPDU guard is a feature that prevents a port from receiving BPDUs. This feature is typically used in a service provider environment where the administrator wants to prevent an access port from participating in the spanning tree. If the port still receives a BPDU, it is put in the ErrDisable state as a protective measure. This command has three states:
•spanning-tree bpduguard enable-This state unconditionally enables BPDU guard on the interface.
•spanning-tree bpduguard disable-This state unconditionally disables BPDU guard on the interface.
•no spanning-tree bpduguard-This state enables BPDU guard on the interface if it is in the operational PortFast state and if the spanning-tree portfast bpduguard default command is configured.
Examples
This example shows how to enable BPDU guard on this interface:
Switch(config-if)# spanning-tree bpduguard enable
Switch(config-if)#
To enable BPDU guard by default on all the PortFast ports, use the spanning-tree portfast bpduguard default command. To return to the default settings, use the no form of this command.
no spanning-tree portfast bpduguard default
Caution Be careful when using this command. You should use this command only with the interfaces that connect to the end stations; otherwise, an accidental topology loop could cause a data packet loop and disrupt the Catalyst 4500 series switch and network operation.
BPDU guard disables a port if it receives a BPDU. BPDU guard is applied only on ports that are PortFast enabled and are in an operational PortFast state.
Examples
This example shows how to enable BPDU guard by default:
Switch(config)# spanning-tree portfast bpduguard default
Switch(config)#
Cheers ,
Satish
wandering_997
At least, they're in different command mode. :)
(config-if)#spanning-tree bpduguard enable
(config)#spanning-tree portfast bpduguard default
The 1st one enables bpduguard on the specified interface.
The 2nd one enables bpduguard on all interfaces which portfast is enabled.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/command/reference/ComRef.html
