12-28-2021 06:27 AM
i all.
I have an IPSec VPN between cisco 4431 in branch office and HQ (build on huawei cloud).
How could I route all the traffic from branch to HQ through the VPN?
"Device" in cloud doesn't support route based VPN and I can't configure huawei cloud with 0.0.0.0 as a local subnet.
It there any solutions or vendor giudes for such deployments?
Could GRE help with traffic routing?
The scheme is : Branch Office (cisco 4431) ---ipsec vpn ------HQ (huawei cloud)------Internet
All the traffice from branch must go to Internet through the HQ.
12-28-2021 07:53 AM
what do you have configured, a VTI ? Crypto map ? Post the running configuration of your 4431...
12-28-2021 11:03 PM - edited 12-28-2021 11:26 PM
Hello, Georg.
It is crypto map. running config :
Current configuration : 9066 bytes
! Last configuration change at 10:13:32 MSK Wed Dec 29 2021 by admin
version 17.3
service timestamps log datetime localtime
service password-encryption
service call-home
service unsupported-transceiver
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname xxx
boot-start-marker
boot system flash isr4400-universalk9.17.03.04a.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone MSK 3 0
ip name-server 8.8.8.8
ip domain name xxx
ip dhcp conflict resolution
ip dhcp pool WIFI-CORP
network 10.1.2.0 255.255.255.0
default-router 10.1.2.1
dns-server 10.0.1.31 10.0.1.155
address 10.1.2.66 hardware-address 0182.f775.e817.93
ip dhcp pool WIFI-GUEST
network 10.1.3.0 255.255.255.0
default-router 10.1.3.1
ip dhcp pool CAS
network 10.1.7.0 255.255.255.224
default-router 10.1.7.1
login on-success log
subscriber templating
no device-tracking logging theft
crypto pki trustpoint TP-self-signed-4224506021
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4224506021
revocation-check none
rsakeypair TP-self-signed-4224506021
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
no license feature hseck9
license udi pid ISR4431/K9 sn FOC25400P44
license boot level securityk9
memory free low-watermark processor 69075
diagnostic bootup level minimal
username xxx privilege 15 secret 9 xxx
redundancy
mode none
crypto ikev2 proposal CLOUD
encryption aes-cbc-256
integrity sha512
group 14
crypto ikev2 policy CLOUD
proposal CLOUD
crypto ikev2 keyring CLOUDKEY
peer CLOUD
address 37.18.115.46
pre-shared-key xxx
crypto ikev2 profile CLOUD
match identity remote address 37.18.115.46 255.255.255.255
authentication remote pre-share
authentication local pre-share
keyring local CLOUDKEY
crypto ipsec transform-set TS esp-aes 256 esp-sha256-hmac
mode tunnel
crypto map CLOUD 10 ipsec-isakmp
set peer 37.18.115.46
set transform-set TS
set ikev2-profile CLOUD
match address VPN-SBERCLOUD
interface Loopback0
ip address 10.1.1.225 255.255.255.255
interface GigabitEthernet0/0/0
description LAN
ip address 10.1.1.241 255.255.255.240
ip nat inside
ip ospf 1 area 0.0.0.0
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
description CAS_SERVER
ip address 10.1.7.1 255.255.255.224
ip nat inside
negotiation auto
interface GigabitEthernet0/0/3
description INTERNET
ip address 213.79.107.186 255.255.255.252
ip nat outside
load-interval 30
negotiation auto
crypto map CLOUD
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
router ospf 1
router-id 10.1.1.225
redistribute connected
redistribute static
default-information originate
router bgp 65001
bgp log-neighbor-changes
neighbor 213.79.107.185 remote-as 8732
ip http server
ip http secure-server
ip forward-protocol nd
ip tftp source-interface GigabitEthernet0
ip nat inside source list LAN_NAT interface GigabitEthernet0/0/3 overload
ip access-list extended LAN_NAT
10 deny ip 10.1.0.0 0.0.7.255 10.0.0.0 0.0.255.255
20 deny ip 10.1.0.0 0.0.7.255 192.168.200.0 0.0.7.255
90 permit ip 10.1.7.0 0.0.0.31 any
100 permit ip 10.1.2.0 0.0.0.255 any
ip access-list extended VPN-SBERCLOUD
10 permit ip 10.1.0.0 0.0.7.255 10.0.0.0 0.0.255.255
ip access-list extended VPN-VAVILOVA
10 permit ip 10.1.0.0 0.0.7.255 192.168.200.0 0.0.7.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 15 0
transport input ssh
transport output all
line vty 5 15
transport input ssh
end
12-29-2021 12:16 AM
--> How could I route all the traffic from branch to HQ through the VPN?
What traffic (which local subnets) do you want to be routed to the HQ (through the VPN) ? What about Internet traffic from the Branch, does that have to go though the VPN as well (and exit to the Internet at the HQ) ?
01-12-2022 04:37 AM
What traffic (which local subnets) do you want to be routed to the HQ (through the VPN) ? 10.1.8.0/24
What about Internet traffic from the Branch, does that have to go though the VPN as well (and exit to the Internet at the HQ) ? Yes, traffic from the Branch has to go to Internet through HQ (throough VPN)
12-28-2021 11:13 AM - edited 01-15-2022 06:17 AM
12-28-2021 11:05 PM
MHM Cisco World, could you provide me with more details or examples about dynamic map?
12-29-2021 12:31 AM - edited 01-15-2022 06:17 AM
