Catalyst SG550x Stackable Switch Backup Automation - Kron
laurathaqi
Level 3
Level 3
Dear Cisco community,
I have some switches of Catalyst 2960 and am managing the Backup via Kron jobs as a way of automation.
However, I also have an SG550X Stackable Switch which is mainly managed via GUI, as the CLI does not accept most of the commands. Due to this, I am having issue to automate the backup as it does not accept the Kron command.
Do you have any recommendation, how i can automate the backup of the running-config in this device?
Thank you,
Laura
Apologies, that is the only option available in this model.
never had chance to play this models, may try SSH using expect to push show run  redirect to TFTP or copy run to tftp
BB
Hi @balaji.bandi
Thank you for your valuable feedback!
I have checked the documentation and I don't see a way on automatizing the process. Is there a way to do the process happen automatically, without me having to do this manually every time I need a backup!?
Thank you,
Laura
BB
