BRIDGE_ASSURANCE_BLOCK on random VLANS on a single etherchannel
kai schoene
Hi!
I'm having serious issues with bridge assurance blocking random vlans at random times on a single etherchannel.
this occurs on the 6500 side of the connection.
the 6500 is connected to a vPC on a couple of nexus 5596's.
I cant for the life of me figure out what is causing this and need a little assistance on what to troubleshoot.
debug spanning-tree all gives 0 results on the 6500.
no logs on the 5596's or any of the other switches in the network shows any signs of root cause.
sample of logs from the 6500 the last few minutes:
Aug 12 2016 14:30:59.835 CEST: %SPANTREE-SP-2-BRIDGE_ASSURANCE_BLOCK: Bridge Assurance blocking port Port-channel1 on VLAN1372.
Aug 12 2016 14:31:05.861 CEST: %SPANTREE-SP-2-BRIDGE_ASSURANCE_UNBLOCK: Bridge Assurance unblocking port Port-channel1 on VLAN1372.
Aug 12 2016 14:33:20.174 CEST: %SPANTREE-SP-2-BRIDGE_ASSURANCE_BLOCK: Bridge Assurance blocking port Port-channel1 on VLAN0061.
Aug 12 2016 14:33:26.174 CEST: %SPANTREE-SP-2-BRIDGE_ASSURANCE_UNBLOCK: Bridge Assurance unblocking port Port-channel1 on VLAN0061.
Aug 12 2016 14:33:45.290 CEST: %SPANTREE-SP-2-BRIDGE_ASSURANCE_BLOCK: Bridge Assurance blocking port Port-channel1 on VLAN0669.
Aug 12 2016 14:33:51.333 CEST: %SPANTREE-SP-2-BRIDGE_ASSURANCE_UNBLOCK: Bridge Assurance unblocking port Port-channel1 on VLAN0669.
Aug 12 2016 14:34:36.519 CEST: %SPANTREE-SP-2-BRIDGE_ASSURANCE_BLOCK: Bridge Assurance blocking port Port-channel1 on VLAN0600.
Aug 12 2016 14:34:42.530 CEST: %SPANTREE-SP-2-BRIDGE_ASSURANCE_UNBLOCK: Bridge Assurance unblocking port Port-channel1 on VLAN0600.
kai schoene
config etherchannel 6500:
interface Port-channel1
 description UPLINK NEXUS
 switchport
 switchport mode trunk
 mtu 9216
 spanning-tree portfast network
interface TenGigabitEthernet5/5
 description N5K-01 Eth 1/32
 switchport
 mtu 9216
 channel-protocol lacp
 channel-group 1 mode active
 spanning-tree link-type point-to-point
interface TenGigabitEthernet5/4
 description N5K-02 Eth 1/32
 switchport
 mtu 9216
config Nexus:
N5K-01:
interface port-channel3079
  description UPLINK 6500
  vpc 3079
interface Ethernet1/32
  description C6500 Ten5/4
  spanning-tree port type normal
  channel-group 3079 mode active
N5K-02:
  vpc 3079
ahmedshoaib
Level 4
Level 4
Hi;
The link between Cat 6500 & Nexus 5596 is block due to bridge assurance due to you enable Bridge assurance on one side (Cat 6500) not on Nexus 5596.
Bridge Assurance is enabled only on spanning tree network ports that are point-to-point links.  And both ends of the link must have Bridge Assurance enabled.
If the device on one side of the link has Bridge Assurance enabled and the device on the other side either does not support Bridge Assurance or does not have this feature enabled, the connecting port will be blocked.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/stp_enha.html#wp1055344
To fix the issue, you need to enable the Bridge assurance on Nexus 5596 or remove Bridge assurance from Cat 6500.
Nexus 5596: (Enable Bridge assurance)
N5K-01:
 spanning-tree port type network
N5K-02:
Thanks & Best regards;
To add it what Ahmed said, It would be better to disable the BA on 6500 as BA is not recommended for VPC member ports.
For access switches connected to vPC domain, use the following guidelines/best practices: Strong Recommendations:
● Enable STP port type “edge” and port type “edge trunk” on host ports © 2015-2016 Cisco and/or its affiliates. All rights reserved. This document is Cisco Public Information. Page 67 of 129 ● Enable STP BPDU-guard globally ● Disable STP channel-misconfig guard if supported by access switches ● Do not enable Loopguard on vPC (disabled by default) ● Do not enable Bridge Assurance on vPC
http://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
I think the best solution will be to remove the below from 6500 Port-channel to disable BA on this link.
Also ensure the above removes the same from 5/4 and 5/5 else remove it from there too.
Hope this helps,
Madhu.
