bridge-group # priority
Sam Oesterling
I just wanted to ask a simple question to make sure I have this right.  I'm trying to create layer 2 redudancy to our CME router.  I thought it would be best to make sure all traffic egresses and ingreses from the same interface unless that interface or the switch it is connected to if offline.  Do I have the right confguration in mind to get this done?  I want to make sure nothing funky happens with STP.  Or would etherchannel be better?
cisco 3845 g0/1 <--> cisco 3750 stack switch 1
cisco 3845 fa0/1/0 <--> cisco 3750 stack switch 2
bridge irb
bridge 1 route ip
int g0/1
no ip address
bridge-group 1 priority 2
No ip directed-broadcast
int fa0/2/1
bridge-group 1 priority 4
int bvi 1
ip address 10.10.10.1 255.255.255.0
service-policy output lan_voip_qos
bridge 1 route ip
John Blakley
If one of the routers will only be used in case of failover, I would configure HSRP on the routers for failover. If you're wanting to load balance, you'll need GLBP.
HTH,
John
HTH, John *** Please rate all useful posts ***
HTH,
John
John,
I'm trying to create L2 redundancy between the router and the 3750 stack.  I will be also configuring HSRP for router redundancy, but I would rather the 3845 stay in operation if it is just a L2 failure.
Brantley
