Bridge with QOS with my cisco router
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-21-2012 08:34 AM - edited 03-07-2019 05:04 AM
I want to configure a single bridge to implement QOS for the videoconference and telephony.
No routing ip. Only a transparent bridge. This is my config. Do you know what is the problem ?
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname R1
ip subnet-zero
no ip domain-lookup
bridge irb
!-- This command enables the IRB feature on this router.
interface Ethernet0/0
no ip address
no ip directed-broadcast
bridge-group 1
!-- The interface E0 is in bridge-group 1.
Interface Ethernet1/0
no ip address
bridge-group 1
!-- IP between bridged interfaces and routed interfaces.
ip classless
bridge 1 protocol ieee
!-- This command enables the bridging on this router.
bridge 1 route ip
!-- This command enable bridging as well routing for IP protocol.
line con 0
transport input none
line aux 0
line vty 0 4
end
- Labels:
LAN Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-21-2012 08:47 AM
Neither one of the physical interfaces gets IP, but you need to configure a BVI interface with IP.
interface BVI1 ip address xx.xx.xx.xx 255.255.255.0
For more info refer to this link:http://www.cisco.com/en/US/tech/tk389/tk815/technologies_tech_note09186a0080094663.shtml
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-22-2012 06:55 AM
I reconfigured my bridge. I'm able to ping the bvi interface with a pc and ping a pc with bvi interface. But, the traffic don't pass the bridge. My objective is simple. I want a bridge to configure QOS. Without reconfigure my default gateway etc.
Router#config t
Router(config)# bridge irb
Router(config)# bridge 1 protocol ieee
Router(config)# bridge 1 bridge ip
Router(config)# bridge 1 route ip
Router(config)# interface bvi
Router(config-if)# ip address 192.168.53.241 255.255.255.0
Router(config)# interface ethernet0/0
Router(config-if)# bridge group 1
Router(config)# interface ethernet1/0
Router# sh int irb
I readed a couple of documentations. I don't understand what is the problem.
