Bridging an subinterface with physical port
CiscoMen
On my Cisco C891F, I'm trying to bridge between a sub interface and a physical port (configured with an access vlan 401) as represented in the bellow diagram :
LAN 1 ----- > Port G7 ( vlan401 Untagged) - C891F-01 - Port G8.401 <------ > Port G3 (trunk) - C891F-02 - Interface vlan401
Configuration :
interface GigabitEthernet8.401
 description Interco-WAN-401
 encapsulation dot1Q 401
 no cdp enable
 bridge-group 10
interface Vlan401
 no ip address
 bridge-group 10
end
The ping between LAN-1 and the Gateway configured on Interface vlan401 of C891F-02 doesn't work !!
Can anyone help me on this topic. Thanks
mlund
Level 7
Level 7
Thanks for this return. I've made the same configuration and I had this result :
1. From the Central router : i can ping both sides
2. From each side i can ping the central IP configured on interface BVI, but I can't ping the other side !!
Here is the configuration :
I just changed me topology :
Interface vlan501 - SW-LAN 1 -Port G7 (trunk) <----- > Port G7 ( vlan501 tagged) - C891F-01 - Port G8.401 <------ > Port G3 (trunk) - C891F-02 - Interface vlan401
Central router : C891F-01
bridge irb
bridge 10 protocol ieee
bridge 10 route ip
interface GigabitEthernet7
 switchport trunk allowed vlan 1,2,501,1002-1005
 switchport mode trunk
 no ip address
 spanning-tree portfast
 description WAN
 mtu 1514
 no ip address
 no ip redirects
 no ip unreachables
 ip flow ingress
 duplex auto
 speed auto
 media-type rj45
 description Interco-To-C891F-02
 no cdp enable
 bridge-group 10
interface Vlan501
 description Interco-To-LAN-1
 no ip address
 bridge-group 10
interface BVI10
 mtu 1514
 ip address 192.168.10.254 255.255.255.0
end
SW-LAN 1 :
interface Vlan501
 ip address 192.168.10.51 255.255.255.0
end
 no ip address
end
Central router : C891F-2
interface Vlan401
 ip address 192.168.10.41 255.255.255.0
end
interface GigabitEthernet3
 switchport trunk allowed vlan 1,2,401,1002-1005
 no ip address
end
Could you help me PLZ.
