bridging pim-dm to pim-sm
jschweng
I have some checkpoint firewalls which are receving multicast from a WAN.
The Firewalls are configured with pim dm on the interface to the inside network.
and the interface is setup with static-groups whcih forward the packets to the inside network.
The inside network is configued for pim-sm with an RP which is not known by the firewall.
I cannot run pim dm on the inside network.
Will the inside pim-sm switches receive the multicast and setup the S,G states so i can route that to the rest of the inside network?
2 Accepted Solutions
Hello Martin,
Check the following output taken from
For IP PIM multicast, Cisco recommends Sparse-Mode over Dense-Mode. In the midst of our network migration, we have a new network operating in Sparse-Mode with Anycast rendezvous point (RP) but our existing network is still operating in Dense-Mode. To bridge two different modes across both PIM domains, we should use the
ip pim dense-mode proxy-register
command on the interface leading toward the bordering dense mode region. This configuration will enable the border router to register traffic from the dense mode region (which has no concept of registration) with the RP in the sparse mode domain.
I think that should solve the registration problem
Let me know what you think
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Martin,
Hey man.. My pleasure.
Glad to know that I could help,
Remember to rate all of the helpful posts ( Hit the 5 star option at the left of the messages) and mark the question as answered so future users can learn from this,
Julio Carvajal
8 Replies 8
Julio Carvajal
They are 2 different routing protocols, both of them for Multicast traffic. They way they work is different so to make this network work as it should you then will need to set only routing protocol...
Running Sparse mode the routers should first register with the RP.. In this scenario the firewall will never register with the inside RP then not allowing the communication
Julio Carvajal
how can you bridge a dense mode routing domain to a sparse mode doman
and send multicast from one to the other then >
jschweng
If the Firewall is forwarding packets to the next hop on the inside network.
and that router is configured with pim sm  AND its the RP
then wouldnt it be considered the first hop router
and by the RFC send register messages to itself and build the S,G state?
how do sources register if they are  directly connected to the RP?
Wouldnt this be the same thing.
Hello Martin,
Julio Carvajal
awesome  - thank you sir
Hello Martin,
Julio Carvajal
Hi Julio, Nice information. I am working on a quiet similar design. The WAN uses DM and the firewall only uses SM, the internal network also uses DM.
The current network is configured with only one PIM DM domain. The problem is that the firewall does not support DM but only SM.
Is it possible to bridge the same PIM domain the same way using the neighbor routers with the proxy register command?
