Bridging
qwertys21
Hi All,
I keep hearing this trerminology, bridging the network, the netwrok is bridge.
What exactly are they trying to get across?
guruprasadr
Level 7
Level 7
HI,
Refer Link below:
http://cisco.com/univercd/cc/td/doc/cisintwk/ito_doc/bridging.htm
There are lot of CISCO Documents explaining the same.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
