Broadcast storm prevention
cuellar52
I just wanted some advice last week while our company was doing some refurbishment a hired contractor came in and plugged on ethernet cable from one wall port directly into another wall port. This caused the end of the world till I managed to trace the issue, I just wanted to ask if anyone knew good prevention methods for storm control incidents.
The current setup was
4x 3750E poe switch stack for users workstations
That runs 2x dot1q trunks to the
2x distribution 3750G switches
then that runs to the
2x 6500 cores
Once the port was plugged into it's self this created a storm that from the first 3750e poe switch started bleeding the storm up the uplinks to affect finally the 6500 cores causing a halt to the entire system.
Standard configuration of a workstation port
interface GigabitEthernet1/0/1
description *** WORKSTATION PORT ***
switchport access vlan 40
switchport mode access
no logging event link-status
mls qos cos override
no snmp trap link-status
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
spanning-tree guard root
end
and configuration on all switches
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast bpduguard default
Ins't 802.1w spanning tree rapid met to to prevent this issue? or is portfast stuffing this up?  My current solutuion would be to enable on all workstation interfaces storm-control
storm-control broadcast level 20
storm-control action shutdown
ANY OTHER IDEAS? how this can be prevented?
any help would be great cheers
Eddy
2 Accepted Solutions
cadet alain
when BPDU filter  and BPDU guard are configured at the same time on a port then the BPDU filter takes precedence and so BPDU guard has no effect. You should only use BPDU guard by configuring it globally so it will be enabled on access ports and get rid of the BPDU filter.
Regards.
Alain
Eduardo
I agree with Alain, you need to be very careul with BPDUfilter as it will completely discard BPDUs and you will be vulnerable to a loop between two ports on a switch. I think that this is the fault condition that you described. Please see this post that discusses the same issue:
https://learningnetwork.cisco.com/thread/6604
I think that storm control at 20% and shutdown action could also be very useful. Perhaps make sure that you receive an alert if a port goes into errdisable.
Daniel
6 Replies 6
Mohit Chauhan
Hi Eddy,
"spanning-tree portfast bpduguard default" should ideally make all ports enabled with bpduguard, which basically means that if there is any bpdu detected on that port, it is shut down "err-disbale" status.
Those wall ports should be going to the access switches and I would double check those ports having bpdu guard enabled.
Also, it is a good practise to keep unused ports part of a bogus VLAN, and make sure this VLAN is shutdown. I usually use VLAN999 for the same.
Hope the above helps.
Mohit
cadet alain
Regards.
Alain
cuellar52
Hi Cadet Alian,
Thankyou very much for the advice you have provided, I tried the setup you suggested in a lab and SUCCESS!
What I have done is
switch running-config is like this
and Interface is
no cdp enable
end
I have removed command spanning-tree bpduguard from the interface and have just left this feature enabled in a global scale. But I left the spanning bpdufilter in the interface. This worked in the test lab.
Would this setup be the ideal setup you were suggesting Cadet Alain?
I would completely get rid of the BPDU filter feature and let the BPDU guard do the trick on access ports.
Regards.
Alain
Eduardo
Daniel
cuellar52
Brillant!! thanks for all your help everyone!
I will be disabling all BPDU filtering features on all my workstation access switches and I will be enabling BPDU guard Globally as this has worked fantastic in a lab.
If anyone is keen to tackle on last questions please help.
I noticed in my config that each workstation port has rootguard enabled.
no cdp enable
end
This is to prevent a switch with a higher prioity coming into the network and taking the root bridge postion. I wouldn't think this feature needs to be enabled on all workstations ports? After all BPDU guard will err-disable any interface that gets any type of BPDU.
Wouldn't this feature best be suited to be enabled on the trunk port going up to the distrubtion switch from the access port switch? Hence just in case something did get pass it would never get to the core root bridge?
Is this correct?
