Broadcast suppression packet per second
irshad.saifi
I am trying to enable broadcast control in my network.
I am using layer2 2950 and 3550 switches.
someone please tell me what is the ideal packets per second must be set on a particular interface.
by default it's rising 500 and falling 250.
When i set it to default the ports were automaticalls shuts....
Need help from Cisco...
Irshad
ehirsel
Level 6
Level 6
Do you have access to a packet sniffer, such as the Nework Associates's SNIFFER product or the Etherreal product?
If your ports are being shutdown at 500 packets per second broadcast rate, I would look for signs of a large ARP query. Ususally that is a sign of a virus attack, or some misconfigured software that is dynamically detecting what devices are on the same subnet as the workstation the code is running on.
How much broadcast is too much depends upon your traffic pattern. I would run the protocol analyzer and see what it states. If you need more help, let me know.
