Cisco 2950 Gigabit interface trunking
ciscotech4u
This is the small part of the network design that i want to seek advice from the forum .
++ we have two cisco 2950 switch
switch1 ==gigabit trunk == switch2 .
we want trunking to enable between these two two switches by using there gigabit ethernet interface ie
switch 1 interface GigabitEthernet0/1 is connected to switch 2 interface GigabitEthernet0/1 and switch 1 interface GigabitEthernet0/2 is connected to switch 2 interface GigabitEthernet0/2.
i need advice in following areas
++ what cable do we need to connect these switches (i guess cross over cable will do )
++ do we have configuration on the tech tip page
for achieving the same ?
for the trunk connection you need a four twisted-pair crossover cable:
Figure B-11 Four Twisted-Pair Crossover Cable Schematics for 10/100/1000 and 1000BASE-T Ports
http://www.cisco.com/en/US/partner/products/hw/switches/ps628/products_installation_guide_chapter09186a0080346679.html#wp1020386
You can either configure 802.1Q or an ISL trunks between your switches. For 802.1Q the configuration would look like this:
Switch1
switchport trunk encapuslation dot1q
switchport mode trunk
Switch2
And for ISL encapsulation, the configuration would look like this:
Switch1
switchport trunk encapuslation isl
switchport trunk encapsulation isl
Switch2
You could also configure a GigaChannel to bind both interfaces into one logical link, for better throughput. For 802.1Q:
Switch1
interface Port-channel1
channel-group 1 mode on
Switch2
And for ISL:
Switch1
Switch2
HTH,
GP
Thanks man !! i am preety much set the info that you have given to me -- :)
