Brocade ICX6450-24-HPOE recommend a compatible Cisco Switch
Terryrw
I have a client that is currently running a Brocade ICX6450-24-HPOE switch. They would like to replace this switch with a comparable Cisco switch. I'm not well versed with route/switch and was hoping someone could help me make a recommendation or two. They mentioned Meraki however I don't know quite enough to know if that would be considered a comparable solution.
Thank You
Thank You
Terry
Reza Sharifi
Terryrw
Thank you Reza, I will have a look.
Thank You
Terry
