Buffers in a switch
carl_townshend
Hi There
I have recently been looking at the 9300 line of switches and I have noticed they do the UXB series which have 64Mbit buffers instead of 32Mbit on the other models.
What are the benefits of these larger buffers as I thought these switches are line rate (non blocking)?
is it where you have an oversubscription of ports going to a smaller bandwidth uplink port for example?
Cheers
Joseph W. Doherty
You can often easily oversubscribe any port if there are multiple ingress ports sending data to it.  I.e. you don't always need to have a larger bandwidth link send data to a smaller bandwidth link.
"Line rate" just means the port can sustain the full rate, indefinitely.  Usually billed as a feature when all the device's ports can do so, concurrently.
If the oversubscription is temporary (i.e. short duration), that's where buffering comes into play.  The larger your buffer resources, the more data you can buffer before you need to drop any.  (As buffer memory, generally, needs to be "high speed", it's expensive, which is why devices have limited amounts of it.)
