BUS TERMINATOR HOW IT WORKS ???
Sakthi vel
I know Terminators are used to avoid signal bounce in the BUS topology but I want to understand how the signal bounce can happen in Bus topology.
Please help me to understand clearly with technical notes.. you can post on Electronics terms also to understand
Sakthivel M
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
My understanding, the signal bounces (or reflects) off the end of the physical "wire".  A terminator dampens the reflection.
Hi Joseph,
I Understand signal Bounces at the end of the wire, But why it bounces... I'm not able to get the answer for this anywhere.
Disclaimer
Posting
Physics.  The signal wave "sees" the end of the wire as a "wall" and will reflect off it
Drop a coin it a pot of water and you'll see the waves reflect off the pot's sides.  Same principle, I believe.
